Cruise control question
Posted: Sat Jul 04, 2009 10:36 pm
by Brenner5
I'm looking to install my cruise control kit tomorrow, i can't figure out some of the wires, can anyone help?
Re: Cruise control question
Posted: Sat Jul 04, 2009 11:30 pm
by badassyas
clutch switch and erm an extra.... i think
Re:
Posted: Mon Jul 06, 2009 10:30 am
by Brenner5
Thanks,
This is exactly what I needed!!
Installed most of the kit yesterday, just need to figure out whether the switch is a clutch or brake switch..
I put that white switch on myself initially it had another connector which just sent a wire back into it.
Re:
Posted: Mon Jul 06, 2009 3:14 pm
by hezicar
The brake input is picked up out of the panel behind the glove box the only switch you need to install is the clutch switch. If you don't have the correct bracket for it (like I didn't) you can simply cable tie it with two strong cable ties to the steering column has worked perfectly for the five years I've had mine installed. Yours looks like it is a clutch switch.
