Removing Intake Manifold
Posted: Fri Jun 26, 2009 5:16 pm
by krismac
Are there any guides on how to remove the intake manifold on a m20b25. I don't have the workshop manual or anything for the car. I have searched on here but couldn't find anything that good.
Is there anything I need to be particularly aware of?
Kris
Re: Removing Intake Manifold
Posted: Fri Jun 26, 2009 5:58 pm
by gudgeon
I've done it on my M20B20.
You'll need a good selection of socket extensions and universal joints.
Look out for the oil return pipe underneath and it's o-rings.
I had trouble getting my IM past the thermostat housing.
There is a fair amount on this if you search, I wrote it up when I added my 325 throttle body.
Posted: Fri Jun 26, 2009 6:04 pm
by TheHeap
it's easy just a bit time consuming
Posted: Fri Jun 26, 2009 8:11 pm
by krismac
Ok I've took off all the nuts, and the manifold is now loose from the engine.... the only thing stopping me from removing it is the oil return pipe and I cant seem to work out how to get this part off?
Anyone got tips on removing the pipe from the manifold??
Re:
Posted: Mon Jun 29, 2009 4:47 pm
by daimlerman
Not an oil return pipe I am afraid,it is part of the crankcase beather system!
Anyway,to remove;
Grip firmly with your mitts and push downwards against it's spring whilst guiding the manifold off it's studs.
To re-fit;
Use a couple of cable ties to compress the spring and do not forget to use new 'O' rings at the top and bottom of the pipe.
