Clutch bearing gone?
charlie_ogden
Thu Jun 25, 2009 3:03 pm
There is a awful screeching noise when the clutch pedal is pressed (started off as a grumble) and when its in gear there is a wine....
Is it a case of a new clutch or can i just get a bearing and how hard is it to do and what sort of cost?
Cheers Charlie
Thu Jun 25, 2009 3:15 pm
Almost certainly the release bearing, and since you've ignored it until it has failed, it will almost certainly have damaged the release forks in the clutch coverplate.
You need a complete clutch kit to sort this, which will be around £100 for a Sachs or Luk one from ECP or GSF.
charlie_ogden
Thu Jun 25, 2009 5:49 pm
Brianmoooore wrote:Almost certainly the release bearing, and since you've ignored it until it has failed, it will almost certainly have damaged the release forks in the clutch coverplate.
Thats sounds ok to me what sort of job is it....?
i would have done it sooner but for the fact i was a way a very very long way from home......
konfuzion
Fri Jun 26, 2009 12:33 am
Mine went a few months ago.. started as a rumble.. then a high-pitched squeal... the bearing was taken out in multiple pieces (not by choice).
Took a few hours to replace mine.
Never (IMO) replace just one part of the clutch.. always do the kit (3 parts).
Regards,
Ian
Kingdoms are run by Kings, Dictatorships are run by Dictators, England must be a Country.
