320i exhaust dilemma
Posted: Fri Jun 12, 2009 10:36 pm
by Robinson
Hey all again.
My 320 touring has developed a hole in the exhaust and i'm trying to work out the best way to resolve the problem.
The front section consists of the downpipe and cat/silencer - has two pipes in two pipes out, does a g reg 320 have a cat? Then there is a centre section which is bolted to the front section by two flanges with gaskets, then the backbox is joined to the centre somewhere i guess?
Anyway my centre & rear system is virtually brand new.
The leak is in the top of the front box where the pipes go into it, it's a small hole rusted through that i could probably gun gum for the time being.
Anyway, is it a cat? Can i fit a non cat downpipe from a different model and still pass the emissions test? If so what model?
While i have your attention, my steering column lower UJ section appears to have a massive amount of play in it, as they tend to do. Where is the cheapest place to get a brand new one?
Look forward to some words of wisdom as always on here!
Re: 320i exhaust dilemma
Posted: Sat Jun 13, 2009 11:38 am
by Robinson
Anyone got any ideas?
I'd have thought if it was a cat it'd reduce to single pipe for the cat?! Meaning it's just a silencer?!
Posted: Sat Jun 13, 2009 3:02 pm
by Brianmoooore
A G reg would only have a cat if the original buyer specified it.
If it's a cat, it will have a lambda sensor screwed into it with a cable coming from it.
Cat fitted or no, it will be emissions tested to the older standard, so will pass with or without a cat, assuming the engine is in reasonable order. E30s normally easily pass emmisions tests.
Repair kit is available from BMW for your steering link.
