Fast Idle
Posted: Sat May 23, 2009 8:00 pm
Hello everyone
Sadly another post on idling issues, I promise i have searched all the forums for answers but have specific questions not covered elsewhere. Sorry for this being such a long post but im trying to give you as much info as i can. I have 325i cab which starts ok and initially idles at 1000rpm then rises up to as high as 1800 - 2000!
So far i have checked the following:
- Air flow meter, checked gate inside moving freely and checked with ohmmeter for proper resistance as gate opens. All seem ok
- Idle control valve, when ignition is turned on ICV buzzes to life and resistances on plug seem to be ok. When the electrical connector for the ICV is removed the engine doesn't rev any faster suggesting that the ECU is telling the ICV to fully open?
- Hoses, the hose to and from ICV look like they've seen better days so i have ordered some new ones along with main hose from AFM to throttle body for good measure.
- Throttle position switch, This does not seem to click with the ignition on and throttle open so i removed the plug and tested with a circuit buzzer. It does not show any circuit on the appropriate pins with the throttle in closed position but does when 3/4 open.
My questions....
1. I am going to first attempt to remove the tps and give a good clean but will probably replace. Does anybody have any tips in removing. i.e. do you get under the car and unscrew just the switch or is removing the throttle body easier?
2. Can i attempt to trick the ECU into thinking the throttle is shut by inserted a piece of wire in the plug to see if this helps with idle?
3. How do you adjust the tps? I haven't got under the car to have a good look at how it works yet but do you rotate it slightly?
Thanks for reading and any help would be greatly appreciated.
My questions....
