how to remove this shadowline trim?
e30_singh
Wed May 20, 2009 9:35 pm
If I remember correctly there are screws that hold it on from the inside.
cro320
Thu May 21, 2009 3:55 pm
e30_singh wrote:If I remember correctly there are screws that hold it on from the inside.
how to reach those?
MrWhite
Thu May 21, 2009 4:19 pm
If its the B-pillar one you're removing you remove the seatbelt top hanger and the coat hook from inside and there will be two 10mm nuts you can get at with a small socket. Undo those and you should be able to (gently) pry off the trim.
rust never sleeps
cro320
Thu May 21, 2009 10:59 pm
MrWhite wrote:If its the B-pillar one you're removing you remove the seatbelt top hanger and the coat hook from inside and there will be two 10mm nuts you can get at with a small socket. Undo those and you should be able to (gently) pry off the trim.
thanks fella
MrWhite
Thu May 21, 2009 11:06 pm
No bother. I only know this because I took one of mine off the other day to get at the rusty but underneath :?
rust never sleeps
cro320
Fri May 22, 2009 8:05 pm
MrWhite wrote:No bother. I only know this because I took one of mine off the other day to get at the rusty but underneath :?
I tried today but plastic inside seems too tight
MrWhite
Fri May 22, 2009 10:01 pm
Which plastic bit do you mean?
rust never sleeps
cro320
Fri May 22, 2009 10:35 pm
MrWhite wrote:Which plastic bit do you mean?
near to the window inside
cro320
Fri May 22, 2009 10:37 pm
well my brother says don't bother with removing and buying new, just paint it satin black
cro320
Mon May 25, 2009 12:15 am
I tried with paint and messed all up :cry:
looks nasty...
tommorow I will order new trim
stereotemps
Mon May 25, 2009 11:29 am
"If its the B-pillar one you're removing you remove the seatbelt top hanger and the coat hook from inside and there will be two 10mm nuts you can get at with a small socket. Undo those and you should be able to (gently) pry off the trim"
mr white hod do you put this section back on took it off 2 spary and havin difficulty puttin it back on, do i need 2 take the rear quarter window out maybe?
MrWhite
Tue May 26, 2009 10:34 am
Not got as far as fitting it back on yet. Maybe somebody else can shed some light on this? I was hoping it'd just push back into place.
rust never sleeps
cro320
Fri May 29, 2009 7:06 pm
got the new one today but still can't remove old one... :?
http://img13.imageshack.us/img13/9569/slika014large.jpg
cro320
Sun May 31, 2009 2:21 pm
no one?
mash
Sun May 31, 2009 2:45 pm
The first part of this E30 Wiki page on removing rear quarter windows might help
http://www.e30zone.net/e30zonewiki/inde ... er_Windows
I did it a while back, don't remember any problems
cro320
Sun May 31, 2009 6:02 pm
it's a door trim not rear body one
stereotemps
Sun May 31, 2009 10:33 pm
put the window right down and then pull out the rubber seal that sits in the door, where glass sits when closed! you'll see some small clips inside the door upright (sits next to b pillar) that you can open with a flat bladed screwdriver then it should just pull off , bein careful not to bend it, unclip the side nearest back wheel first, you may need to partly remove top and bottom trims as they slightly overlap they are clipped on with the same clips! pretty por description sorry but i hope it helps
MrWhite
Sun Jul 05, 2009 4:49 pm
stereotemps, did you have any luck getting the rear quarter trim back on? The time has come for me to refit mine and, as you say, it isn't wanting to push on. Did you have to take the glass out?
rust never sleeps
MrWhite
Sun Jul 05, 2009 5:35 pm
I've just done it so I can answer my own question: Yes, the window does come out first.
rust never sleeps
