E30 M3 S14 2.3 1988 ,I have a problem with overfuelling I think , If i rapidly put the accelator all the way to the floor my car starts missing like crazy but if i gently accelarate she'll go all the way to 6500rpm without missing but then starts to miss again from 6500rpm to the limiter (if it reachs the limiter).Also sometimes when i turn off the ignition the engine attempts to keep running for a couple of seconds ,would this be a timing issue and if so how would do you adjust the timing? Can you adjust the timing?
Anyways its driving me crazy along with the buzz off the gearstick above 4000rpm which I would also like a fix for if anyone else has had this problem.
Please someone tell me what to do
