Drain Holes
Posted: Mon Apr 20, 2009 1:46 pm
by SilverShadow
Does anyone know where the drain holes are in the hood compartment for a convertible.
Checked over the weekend and there is quite a lot of water there - so Im assuming the holes are blocked?
Re: Drain Holes
Posted: Mon Apr 20, 2009 1:54 pm
by ImysE30
They are right at the bottom on each side, poke around with a metal wire or something similar and that should do the job. There is a pic on here somewhere, i shall have a look
Re: Drain Holes
Posted: Mon Apr 20, 2009 1:56 pm
by ImysE30
Re: Drain Holes
Posted: Mon Apr 20, 2009 3:20 pm
by SilverShadow
Cheers Imy - Will give it a go tonight after work
Will a coat hanger do the trick or does it need to be thinner?
Re: Drain Holes
Posted: Mon Apr 20, 2009 3:24 pm
by Chase007
This is a nightmare i cant see them Ahhhhhhhhhh
Re: Drain Holes
Posted: Mon Apr 20, 2009 3:25 pm
by ImysE30
Coat hanger should be fine as long as it's not too thick
The water should drain out from under the sill near the doors. Also make sure these are not blocked as well.
Re: Drain Holes
Posted: Mon Apr 20, 2009 3:27 pm
by ImysE30
Chase007 wrote:This is a nightmare i cant see them Ahhhhhhhhhh
Neither could I, I even used a torch but still very difficult to see. I just got the wire and poked it everywhere inside and it did the job
Pour some water in after to check to see if they have unblocked
Re: Drain Holes
Posted: Tue Apr 21, 2009 3:11 am
by Chase007
ImysE30 wrote:Chase007 wrote:This is a nightmare i cant see them Ahhhhhhhhhh
If they get blocked do they overflow and you end up with water in your rear passenger footwells?
Re: Drain Holes
Posted: Tue Apr 21, 2009 8:33 am
by DaveD
yes ...and also remember to check the exits in the sills just in front of the rear wheels....they can get blocked too
