Bespoke Air Flow meter for LPG?
Posted: Mon Jul 18, 2005 10:27 am
by k9
Hello
I have a 1990 325i touring which is LPG converted with a single point system. It has never ran nice, overfueling and running poorly. I don't use the gas anymore, just petrol, still poor.
I replaced the air flow meter and it ran a bit better 20%. I took it for a diagnostics today and they told me they could not do a diagnostics as the air flow meter was faulty, the resistance bridge in the meter had snapped.
I expalined I had the original one and took that down, by sight he diagnosed this one to be faulty too, and expalined a bespoke air flow meter was needed to run on gas and fuel.
I outlined that surely the LPG converter would have put on a bespoke air flow meter if it was needed? Does anyone know where an LPG convered car needs a bespoke set up of the air flow meter? This sound like Bollox to me?
Apparently no futher diagnostics can be performed as the car is running too rich to do any diagnostics?
Anyone had a faultly air flow meter before? What are the symptoms?
Posted: Mon Jul 18, 2005 10:34 am
by TOURINGDADDY
sounds to me like a load of bollox diagnostic can b performed at any time however if the afm is faulty it would b a waste of time tryin to sort it (i do have a 325 afm 4 sale if u need 1 Ԛ£27 posted) where r u we may b able to meet up and c if this can b sorted out. u really need to utalise the gas kit u have fitted
Posted: Mon Jul 18, 2005 12:25 pm
by philglasgow
hi
do you have any pics of under the bonnet for your conversion, as im going to remove a single point omvl lpg system from my 520 and fit it to my 3 series tourer
Phil
Posted: Mon Jul 18, 2005 12:27 pm
by TOURINGDADDY
i dont im afariad but can get some tomorrow 4 ya. its really easy to fit mate
Posted: Mon Jul 18, 2005 1:02 pm
by philglasgow
Hi touringdaddy
Just in case weve got our wires crossed, im looking for pics of lpg installs and not mafs.
Phil
Posted: Mon Jul 18, 2005 1:12 pm
by TOURINGDADDY
i did asume u wanted pics of instal
£27 for AFM
Posted: Mon Jul 18, 2005 6:13 pm
by k9
I would be happy to pay you Ԛ£27 for your AFM, but could you confirm you know it's working, as there seems to be a lot of dodgy old air flow meteres out there, I've had two already and don't want another!
Why did you take it off? Needs to be the same model as well, I've got the code numbers on the AFM, give me an email on
kanedavies@blueyonder.co.uk to arrange payment etc... I don't think meeting up would be possible as I'm in Birmingham.
Sorry no pics of engine, havent got a camera
K
Re: Bespoke Air Flow meter for LPG?
Posted: Mon Jul 18, 2005 10:37 pm
by Brianmoooore
k9 wrote:Hello
I outlined that surely the LPG converter would have put on a bespoke air flow meter if it was needed? Does anyone know where an LPG convered car needs a bespoke set up of the air flow meter? This sound like bollards to me?
There's no such thing as a bespoke airflow meter for LPG. In fact, the airflow meter's not really needed when running on LPG.
When my kit was first fitted, I was supplied with the wrong size backfire protection device, not once, but twice. I was reluctant to risk loosing the air meter to a backfire, so I drilled a small hole top and bottom of the flap housing, so that I could insert a piece of stiff wire to hold the flap completely open. Ran happily like this for about two months.
If I ran low on gas, and had to run petrol, then I simply opened te bonnet and pulled out the pin.
Where is the gas mixer on your system?
If it is between the air meter and the throttle body, then your LPG system will never work properly unless you fit a flap opening device to the air meter. Maybe this is what your diagnostics "mechanic" is refering to.
