how do i get in boot ?
Posted: Mon Apr 13, 2009 4:10 pm
by beavere30
hi anybody know how i can get in boot without destroying it the doors open n shut with either key or remote but boot stuck shut. n e 1 have n e ideas ?
cheers brett
Re: how do i get in boot ?
Posted: Mon Apr 13, 2009 6:01 pm
by Bob_S
If you insert a cocktail stick into the bootlock, angle it at about 30 degrees upwards the tip will locate in a small hole, lift the stick vertical and then push the key past it, turn the key slightly to the right and then left very quickly, this usually works.
In your dreams boy, 1 post on a forum asking how to get into a locked car.. a ha.
Posted: Mon Apr 13, 2009 7:29 pm
by badassyas
does the key rotate the boot lock barrel at all?
Posted: Mon Apr 13, 2009 7:38 pm
by Dave_M3
Bob_S wrote:If you insert a cocktail stick into the bootlock, angle it at about 30 degrees upwards the tip will locate in a small hole, lift the stick vertical and then push the key past it, turn the key slightly to the right and then left very quickly, this usually works.
:rofl:
Posted: Mon Apr 13, 2009 8:39 pm
by murran
its a specialist tool you need..........
have a read up on it!
http://en.wikipedia.org/wiki/Crowbar_(tool)
winkeye
Posted: Mon Apr 13, 2009 9:41 pm
by fingerman
Obviously not a scouse then :duck:
Posted: Mon Apr 13, 2009 9:54 pm
by ProToZyKo
Think crowbar would break something.
Posted: Tue Apr 14, 2009 12:04 am
by Dave_M3
ProToZyKo wrote:Think crowbar would break something.
Really!!!
Posted: Tue Apr 14, 2009 12:13 am
by murran
id post up a link to a tin opener but i cant be arsed!
Posted: Tue Apr 14, 2009 12:52 am
by robbo86
cheers brett
Pardon!?
allow me
Posted: Tue Apr 14, 2009 2:17 am
by Dave_M3
You can get into the boot without damaging it...
But you need to be able to get into the car first though :D
Posted: Tue Apr 14, 2009 5:00 pm
by mash320i
lol genius
