i can get hold of a m30 afm ending 027...is this plug n play on the E30?i have 325 with 153 box...or do i have to do some adjustement on the spring and so on?
anyone??.....
Tis trueJon_Bmw wrote:Isn't it the usual mod to take the internals out of your m20 afm(curcuitry) and put it in the m30 afm, hence this way you fuel mixture stays the same but you benifit from the large circular intake and exit ports from the AFM.
Only if you have a pre-027 M30 afm as they had a different carbon track. The 027 is a similar track to the M20 so there's no need to swap it.Jon_Bmw wrote:Isn't it the usual mod to take the internals out of your m20 afm(curcuitry) and put it in the m30 afm, hence this way you fuel mixture stays the same but you benifit from the large circular intake and exit ports from the AFM.
Bollocks.Demlotcrew wrote:Waste of time!
Andrew
Templ8e30 wrote:I've been fiddling with this mod on my 2.7 for a few weeks, I backed off the spring tension 5 clicks and left the wiper arm position stock.
I also have an FSE adjustable pressure reg, as standard i had it set to 3.4 bar but with the M30 AFM it runs much sweeter at 3.8 bar so on a standard 325i you'll probably be best around 3.4/3.5 bar.
What induction tube did you use to attach it to the throttle body ?. I browsed the ETK and found the e36 328i bellows and idle control tube to be a perfect fit at both ends.
I also made a stainless steel heatshield/airbox that sits on the original mounts and takes in cold air from the headlights. It works great, after a long fast run last weekend the engine bay was very hot but the walls of the heatshield were stone cold![]()
I'm having this AFM set-up properly at the Dyno tuners on saturday so I'll let you know the verdict.
Cheers,
I played around with this too and belive there is power to be had here ( gareth made 12bhp after a dyno setup on his 2.5 ) i ended up with much the same results but found i got a better idle after playing with swing arm position with the motor at idle ,same fuel pressure too , i think mine ran a bit lean at top end so bottled out without access to dyno setup ! fuel consumption improved !!!
all the best paul
Iain T
I don't know why they didn't use them but BMW SA did on their 2.7 beastiesDemlotcrew wrote:Okay so why didnt Alpina and Hartge use them?
Andrew
BMW SA used alot of things of which most people dont have a real record of. I still stand by my statement.Templ8e30 wrote:I don't know why they didn't use them but BMW SA did on their 2.7 beastiesDemlotcrew wrote:Okay so why didnt Alpina and Hartge use them?
Andrew![]()
Cheers,
Iain T
Hi m8 , what do base your opinon on ? have you fitted many yourself ,or are you going on adams experiance on the rollers ? im sure people here and in the states have had some sucess with this mod , i never had the money to spend on dyno time but am sure there was an improvement in smoothness and mid range respose ,but this of course was just my opinion ,however when tbmw did the article on my car andy drove mine and craigs 325 and said mine was faster so i cant have been losing much power from it either.Demlotcrew wrote:Waste of time!
Andrew
The rubber boot can't stay the same as the M30 afm has a larger outlet than the M20 afm ! How is yours fitted ?.Demlotcrew wrote:What about the Rubber boot? that stays the same, just seems pointles to me.
No ive not installed any of these. But i have a M30 AFM on my car.
Andrew
i understand what you are saying and agree that dyno time is too expesive for this ,however if you have the bits and time i think its worth a go ,i bottled out of running mine coz of the improved mpg and possible weak mixture , im sure gareth posted his results on the old e30 zone and had some sucess with it .If increased power from more airflow is restricted by the size of the boot or tb then why should a cone filter produce more power ,not accounting for loses as temp rises ,not just on m20 engines either but in general, mind you does a cone filter produce more than a stock air box before engine temps rise ? ah questions questions !! i think we will agree to disagree on this on oneDemlotcrew wrote:Thing is paul,
when Bosch make these AFMs they are laser timed at the factory, and i dont think we are able to replicate this at home. There are also associated risks with this type of modification (Running the engine lean enough to melt parts) and i have seen pics of little balls of aluminium from the pistons on the end of spark plug electrodes.
I would say that if done properly you are looking at a little less than what it would cost to get a MAF conversion and you are still faced with the physical restrictions of the AFM design.
Andrew
Thanks mate! Im really happy with the results, The other great thing is that there is plenty to keep me busy with the upgrade options.Shinobi1 wrote:Andrew
ment to say well done on the engine conversionso much has happend while i have been away from the zone !!
cheers ,Paul
new shell too ! you have been busy ,good to be backDemlotcrew wrote:Thanks mate! Im really happy with the results, The other great thing is that there is plenty to keep me busy with the upgrade options.Shinobi1 wrote:Andrew
cheers ,Paul![]()
I was getting tired of the M42 that didnt need anything doing to it, and i would have been wasting money if i thought i could generate any decent power from it.
New shell also!
Good to have you back!
Andrew
