electric mirrors
Posted: Sun Mar 15, 2009 12:47 pm
by kieron
I've finally got round to having a look at the wiring for my mirrors as they havent worked since i got the car. I took the speaker out of the footwell and there are quite a few wires that are not connected to anything:
The car doesnt have electric windows so I thought maybe that might be what they are for. The red and black wires at the bottom, the joint was rusty so i reconnected them.
I took the mirror connections at the top of the door apart and used a meter to see if there was any power and there is 12v at all four.
Also i had a look at the fuse box and the fuse in 19 was 20amp and blown so i have now put in a 10amp temporarily. The heater works fine so it cant be the relay.
Shall i have a look at replacing the switch? Other than the loose wires hanging around or both motors being broken I cant think of anything else.
Do both mirrors have to be wired in correctly for either to work or will one work if the other is wrong?
Re: electric mirrors
Posted: Sun Mar 15, 2009 12:48 pm
by Cook318IS
i think some of those wires that arent connected are for the tweeters that replace the inside mirror blanking plate. Could be wrong though but i think thats them!
Posted: Sun Mar 15, 2009 2:20 pm
by kieron
Im sure i posted a response to this slightly earlier.
Anyway managed to remove the switch from the door and it turned out that the switch wasnt even plugged in! So much for the guy i bought it off saying that they were working the week before and the fuse must have gone. I think he had put a blown fuse in the box to make the story seem true. Plugged in the switch and they are working now.
Good times.
Kieron
