Wobbling When Breaking
Posted: Tue Jul 05, 2005 5:12 pm
by Pal318is
Guys some assistance please......
I had some new discs and pads fitted about a month ago and have run them in about 600miles without any excessive hard breaking, but for the last few days the steering wheel has been shaking when I break?? It wobbles slightly at about 50-60mph but more so when i slow down, I don't know if this has anything to do with the discs and pads?? (EBC Discs and Pagid Fast Road pads) or it's something else?? Balancing, Ball joint etc Any help would be appreciated as this is really pissing me off!! :cry:
Posted: Tue Jul 05, 2005 5:23 pm
by Ade
You could take the front wheels off and measure the run-out of the discs with a guage. Last time I put new discs on I spent ages sanding and cleaning the corrosion from the hub where the disc is bolted to.
Worth it though, ended up with no run-out and improved brakes.
hope this helps?
ade
Posted: Tue Jul 05, 2005 5:44 pm
by jamie325isport
I would get the wheels balance you may have lost a weight or something. Somewhere like kwik fit will do it if it doesnt need doing you dont have to pay. :wink:
Posted: Tue Jul 05, 2005 6:06 pm
by Karan
sounds like they put the discs on wrong......
or whoever did it put them on wrong
take em off... clean area between disc and hub using saindpaper...then refit
Posted: Tue Jul 05, 2005 6:17 pm
by TOURINGDADDY
i would ave said ur discs r out of shape/warped
Posted: Tue Jul 05, 2005 6:18 pm
by jmc330i
Like said above, check that the face of the hub is clean and corrosion free. You want the discs sitting flat on the hub.
But TBH, if its more noticeable when braking it sounds like the discs could have warped. If they are the grooved EBC discs (I think they are directional discs), then as Karan said, check they are fitted correctly. If the grooves run the wrong way it could cause the disc to warp.
Posted: Tue Jul 05, 2005 8:00 pm
by Turbo-Brown
Not that I'm accusing anyone of doing this, but there's an easy way to warp brake discs that we all probably see every day:
If you brake even gently from a moderate speed, say 40 or 50 mph for a set of lights and then leave your foot on the pedal while you wait for the lights to change, you stand a really really good chance of causing high spots / warping of your discs.
The reason for this is that the discs and pads get nice and hot under braking and when you stop leaving your foot on the pedal, not only do you irritate the guy behind, but you also insulate that little area of the disc with a hot pad.
The rest of the disc cools down at a different rate to the hot and insulated bit and hey presto! warped disc!
Might be worth bearing in mind :lol:
Posted: Tue Jul 05, 2005 8:04 pm
by Sjoerd320i
I was just about to say that turbo-brown :wink:
Posted: Tue Jul 05, 2005 8:06 pm
by jmc330i
Thats a very good point.
Turbo-Brown wrote:when you stop leaving your foot on the pedal, not only do you irritate the guy behind
:lol: :lol: :lol:
Posted: Wed Jul 06, 2005 12:00 am
by Jackle
Pal318is hows you control arm bushes? I've had this twice on two cars, I had a definately warped disc on one side so I changed them both, was ok for a week or so then it started wobbling on braking like yours. So my mechanic changed the discs again, only for the wobbling to reoccur a while later. Following advice from here I changed the bushes - they were well knackered, and I never had the problem again, until I got my new car. Again, changing the control arm bushes solved it. :D
Posted: Wed Jul 06, 2005 10:17 am
by Pal318is
Karan wrote:sounds like they put the discs on wrong......
Guys
I had the discs taken off and refit as they weren't sitting right, about 2-3 days after having them orginally put on?? My PAS rack needs replacing, which i have at home ready to go on, but the steering has been squeeking more so the last week or so, could it be a ball joint then?? The brakes have been squeeking more since this has been happening??
Pal
Posted: Wed Jul 06, 2005 8:25 pm
by stanley
i had a simular problem on my last e30 the bottom ball joint it was completely worn out so put in a new on, well had to change tne whole wishbone because the ball joint is sealed unit.The car then stopped perfect
Posted: Thu Jul 07, 2005 10:20 am
by astondg
This is a very simple thing and probably not the cause but just to make sure there are no accidents: make sure the wheel bolts have been done up tight!
Like I said, probably not the cause but I just wanted to make sure.
Checking the other things that have already been mentioned should find the problem.
Aston
Posted: Thu Jul 07, 2005 11:19 am
by Pal318is
Thanks for all the response guys!!!!
Posted: Thu Jul 07, 2005 5:22 pm
by Simon13
My brakes squeek when the pads are not warm enough or i barke gently, plus the disks are sqweeky by nature i think! Probably the same with u as your using fast road pads and grooved disks
I use ATE power disks (grooved also) and Mintex C 1155 competiton pads and these are the daddy can lock them up at 90 when warm in the dry so they work very well when needed!
I would check your control arms as worn stuff on the front end will not help the situation!
Posted: Thu Jul 07, 2005 8:59 pm
by jonbuoy
Sounds like you have a sticky caliper, that will cause one of your discs to warp. If your not confident or experienced enough to check the calipers out then get someone one who does. Its alright replacing new bushes when needed but i still think your gonna replace something to hide whats really wrong. Bit like taking tablets for a back ache, tablets take the pain away but the problems still there :?
