side lights question!!!!!!
Posted: Sun Jan 18, 2009 11:05 am
by cracker
when the ignition is off and side lights on it just lights the little half moons in the headlights,when the ignition is on it lights the dipped beam(dimmer) aswell as the half moon,
is there a relay/resistor i can disconnect so when the ignition is on my side lights lit are just the halfmoons and no dimmed dipped beam!
hope this makes sense
thanks!
Re: side lights question!!!!!!
Posted: Sun Jan 18, 2009 11:47 am
by Brianmoooore
Your car must be an early facelift model. This system was introduced in anticipation of some European legislation that didn't happen, and was dropped after several months.
On the LH inner wing, there are two black round two pin plugs and sockets. Just pull these apart, and the system will be disabled.
If you follow the wires from the plugs that are going towards the front of the car, you will find the resistors, mounted right at the front of the inner wing. These can be removed if you want, or just left and ignored.
Posted: Sun Jan 18, 2009 7:33 pm
by cracker
thanks brian
right ive disconnected the plugs and it works how i want it to,
problem now is the check control panel is saying ive got a bulb blown,
how can i rectify this?
Posted: Sun Jan 18, 2009 9:07 pm
by murran
make a looped plug to plug into the car loom side of the plug, to complete the circuit to fool the car into thinking the bulbs still there??..... :?
Posted: Sun Jan 18, 2009 9:32 pm
by Brianmoooore
Disconnecting these plugs shouldn't upset the check panel!
If you do murran's mod, you'll just have full dipped beams on in the sidelight position!
Posted: Sun Jan 18, 2009 9:39 pm
by cracker
the two plugs i disconnected were sort of tucked behind the expansion tank and abs pump!
is this right?
Posted: Sun Jan 18, 2009 9:46 pm
by Brianmoooore
That's the right plugs.
Posted: Sun Jan 18, 2009 9:53 pm
by cracker
how can i fool the check panel into thinking the lights are normal?
Posted: Sun Jan 18, 2009 9:57 pm
by Brianmoooore
The lights are normal! It's now wired as most E30s are. Whatever is turning your bulb check light on, it's not the disconnecting of the resistors.
The resistors are mounted in a place where they are vulnerable to road dirt, and most have disconnected themselves by now in any case.
Posted: Mon Jan 19, 2009 1:23 am
by konfuzion
I pulled the 2 plugs apart on my motor this morning as I've recently fitted HIDs. Before I fitted them, I had the same "half glow" for side lights and the check panel stayed nice and quiet. Now with the 2 plugs disconnected (behind the header tank).. the check panel light comes on for dipped beam when pulling the headlight switch to the sidelight position. Pulling it right out to headlights doesn't cause any check panel lights to appear though. This is running on an E-plate facelift motor with all lights functioning just fine before and after HID fitment.
Just a FWIW.
Regards,
Ian
