erm....
Posted: Sun Jan 18, 2009 12:07 am
by lowdown
what should go to this??
and where does this go?
haha i was lookin under my bay today and noticed these 2 things not plugged to where they should go... any ideas? :)
Re: erm....
Posted: Sun Jan 18, 2009 12:09 am
by maxfield
I think they're both related to the cat??
Re: erm....
Posted: Sun Jan 18, 2009 12:39 am
by eko
1 throttle position switch
2 looks like fuel breather pipe
Re: erm....
Posted: Sun Jan 18, 2009 9:55 am
by aj_mckay
^+1 Agreed.
Re: erm....
Posted: Sun Jan 18, 2009 6:28 pm
by lowdown
should there be a plug er.. pluged into that then???
Re: erm....
Posted: Sun Jan 18, 2009 6:36 pm
by DHFiS
The elecrical plug might be redundant, there is a similar one in my car that is unconnected. The hose needs reconnecting though.
Re: erm....
Posted: Sun Jan 18, 2009 6:38 pm
by Chris-W
Electrical socket shown is definitely TPS.
Will move this to Tech Help, not Photo Gallery...
Re: erm....
Posted: Sun Jan 18, 2009 6:43 pm
by aj_mckay
DHFiS wrote:The elecrical plug might be redundant, there is a similar one in my car that is unconnected. The hose needs reconnecting though.
Connecting to what? If it's a breather pipe for the fuel tank it needs to be left as it is surely? :?
Re: erm....
Posted: Sun Jan 18, 2009 6:54 pm
by Brianmoooore
Chris-W wrote:Electrical socket shown is definitely TPS..
And definitely needs a plug connected to it!
Where does the other end of the pipe go?
Does this car have a cat? (Or what age and model is the car?)
Re: erm....
Posted: Sun Jan 18, 2009 6:57 pm
by DHFiS
The open end of the rubber hose is marked by a hose clip, if it was meant to be left unconnected it would not have had a hose clip on it.
Re: erm....
Posted: Sun Jan 18, 2009 7:28 pm
by magpie
does it run at present?
without the tps plugged in :?
Re: erm....
Posted: Sun Jan 18, 2009 7:59 pm
by lowdown
its a 325i tourer, it seems to run fine thats why i wonderd if they were ment to have plugs to em, i only noticed it when i was topping my water up
Re: erm....
Posted: Sun Jan 18, 2009 8:21 pm
by stonesie
magpie wrote:does it run at present?
It will but the idle will be high, It wont drive very well at full throttle either.
The pipe looks to have had a clip around it so it need's re-connecting, but im not exactly sure what it's for from that pic.
Re: erm....
Posted: Sun Jan 18, 2009 8:24 pm
by magpie
looks like it may need to go to the throttle body :?
just a guess.if your happy now wait till you plug this in and the tps :wink:
Re: erm....
Posted: Sun Jan 18, 2009 9:28 pm
by Brianmoooore
This engine cannot possibly run anything like properly with the TPS disconnected!
Re: erm....
Posted: Sun Jan 18, 2009 9:42 pm
by lowdown
i cant find a plug to fit it tho??
Re: erm....
Posted: Sun Jan 18, 2009 9:50 pm
by lowdown
Brianmoooore wrote:This engine cannot possibly run anything like properly with the TPS disconnected!
il try and get a video of it tomorrow, iv had it over a month and its ran fine
Re: erm....
Posted: Sun Jan 18, 2009 9:54 pm
by Brianmoooore
I don't want video's! I want three simple questions answered!!!!!
Re: erm....
Posted: Sun Jan 18, 2009 9:57 pm
by stonesie
Find the relays near the coolant bottle under a black cover and trace the wireing back, the TPS wire branches off from that not far down (less that 12" iirc) it's a 3 pin plug.
Once the ECU knows to use it's full throttle map you will see the differance, i did on my M20B20 :)
Re: erm....
Posted: Sun Jan 18, 2009 11:22 pm
by aj_mckay
See what you mean, which kind of indicates it's not a breather pipe as first suspected.
Re: erm....
Posted: Sun Jan 18, 2009 11:26 pm
by Brianmoooore
aj_mckay wrote: See what you mean, which kind of indicates it's not a breather pipe as first suspected.
Means no such thing - depends on the spec of the car.
Re: erm....
Posted: Mon Jan 19, 2009 12:33 am
by magpie
Brianmoooore wrote:I don't want video's! I want three simple questions answered!!!!!
now hurry up if you want it fixed :D
