S50 converted e30 switches off when warm.
Posted: Thu Jan 15, 2009 12:23 pm
by rigbo
Hi guys I'm really stressed about this. Started the car as normal drove around for around five minutes and then it just switched itself off. Its never done this before. Started her up again drove for 30 seconds then went off again. Any ideas guys? Please help. Thanks
Re: S50 converted e30 switches off when warm.
Posted: Thu Jan 15, 2009 1:20 pm
by MJJ_ZX6RR
My M30 did very similar, though it would never restart for love nor money after that first five minutes. After advice on here, I cleaned up the coil connections, and the dizzy rotor and all been perfect since.
Other possibles are the crank position sensor, and the coolant temp sensor (blue on the M30).
Martin.
Posted: Thu Jan 15, 2009 3:08 pm
by hoshy
*disclaimer* having never so much as looked at an S50 I'm not really qualified to answer but it sounds to me like there could be a component overheating in the ECU. Does it get particularly warm/hot and perhaps have a smell to it?
There's a few S50 and general gurus about who will have some good advice but it might be worth at least checking for the above.
Posted: Thu Jan 15, 2009 4:15 pm
by rigbo
Thanks for the advice guys. I'm going to have to book it in somewhere. Seems to be something electrical. So I;m stuck! :x
Posted: Thu Jan 15, 2009 5:47 pm
by DanThe
Where abouts are you?
Posted: Thu Jan 15, 2009 8:59 pm
by rigbo
I'm in Ilford Essex.
Posted: Thu Jan 15, 2009 10:41 pm
by old_skool
Take the inspection cover off the rocker cover and remove a couple of coil packs, look down in the plug bores and make sure they are all dry.
Posted: Thu Jan 15, 2009 11:31 pm
by rigbo
Thanks i'll give that a go in the morning.
Posted: Fri Jan 16, 2009 1:09 am
by Jhonno
If there is water down the plug holes it would start to missfire and run on fewer and fewer cylinders.. I know as Ive been there with my M50
Posted: Fri Jan 16, 2009 1:10 am
by Jhonno
Is it a B30 or a B32?
Posted: Fri Jan 16, 2009 10:41 am
by rigbo
its a 3.0 Jhonno.
Posted: Fri Jan 16, 2009 12:42 pm
by Jhonno
what year?
Where is the ecu mounted?
Posted: Fri Jan 16, 2009 1:00 pm
by zimmerbimmer1
Get the Crank position Sensor checked out if this is faulty the car will not start.
It could be getting hot and breaking down.
Posted: Fri Jan 16, 2009 1:43 pm
by DanThe
Anything major will show up on a diagnostic. If you dont know where to start looking for problems its worth finding someone who can plug it in
Posted: Fri Jan 16, 2009 1:46 pm
by Gibson
I have heard that when the ECU is remounted on these conversions it can lead to it overheating due to lack of airflow. i guess you could try taking off any plastic or sound deadening around the ECU and see if this helps, if it does then its a good chance this is the problem
Posted: Fri Jan 23, 2009 9:47 pm
by Jhonno
Any luck with this? Does sound like something is over heating..
