brake help
Posted: Wed Jan 14, 2009 9:10 pm
by lowdown
so iv had a few issues with juddering and brakes failing when braking hard,
i thought it might discs n pads but all seem fine
is there some sort of ABS sensor that could be faulty?
the problem only seems to be when the ABS should kick in ???
im a bmw n00b so dont be scared of talking to me like im an idiot:)
i do have car/engine knowledge tho
Re: brake help
Posted: Thu Jan 15, 2009 3:42 pm
by Daf318is
Just a thought - but you could eliminate the ABS by taking the relay out and seeing if it still judders.
When you say your brakes look fine have you checked the disks are not warped??
I had something like this on another car - strangely enough it was the steering rack
after changing everything it wouldn't go - but when replacing the rack for different reasons the juddery braking dissapeared!
Re: brake help
Posted: Thu Jan 15, 2009 6:27 pm
by lowdown
il havbe a look at the relay, if the discs are warped would i still get the judder under less heavy braking tho?
Re: brake help
Posted: Thu Jan 15, 2009 6:35 pm
by Oggy
From experience, that depends on how badly warped they are.
If you do a lot of braking from high speeds down to not a lot, or drive hard, left foot braking and such, you may find they're only warped badly enough to notice under heavy braking, on the other hand, they may be bad enough to notice at lower speeds and under more gentle braking.
Worth considering perhaps.
Re: brake help
Posted: Thu Jan 15, 2009 7:13 pm
by e301988325i
track rod ends shot is a possible cause.
