ASC system!?!?!
Posted: Mon Jan 12, 2009 3:29 pm
by Skazka
Hello friend.
Put to itself asc system?
What for this purpose it is required?
There is an experience of the given operation?
Re: ASC system!?!?!
Posted: Mon Jan 12, 2009 3:34 pm
by Bob_S
ASC is Anti Skid Control I believe
It's an electronic stability aid and was never avaliable on an E30.
Basically it stops the car from spinning around when you lose control
Re: ASC system!?!?!
Posted: Mon Jan 12, 2009 3:50 pm
by Skazka
ASC -This system stability control, which can reduce engine power, until the car can start with the place, or to continue the acceleration, without the scroll wheel
Re: ASC system!?!?!
Posted: Tue Jan 13, 2009 8:27 am
by abelai
The ASC (automatic stability control) on my E36 only controls the braking system and can apply any brake on any wheel to keep the car stable. You can have ASC with ATC (automatic traction control) this will then reduce engine power aswell, should the wheels spin up.
So when I drive round a bend and the inside wheel spins up the ASC applies the brake to that wheel to slow it down. This all has the net effect that my rear pads wear down as fast as my fronts if I drive like a fool everywhere.
Re: ASC system!?!?!
Posted: Tue Jan 13, 2009 5:50 pm
by evostormm
Read this;
http://www.318ti.org/notebook/asc/index.html
Don't confuse with DSC ('Dynamic Stability Control').
