Over the last week or so ive cured the steering issues and done a few hundred miles on my new battery... and still have a dodgy idle once warm and now it has even started to stall on me when parking and using full lock...
Im possibly thinking it could now be a faulty TPS? anyobody had similar issues? whats the going rate for a good decent second hand TPS?
dodgy idle issues..
Have you checked for air leaks in the intake hoses, as well as checking the ICV?
There is a way of testing the TPS - don't know it off the top of my head though.
May be a rare case, but I eventually solved my lumpy idle by changing the fuel filter - the sh*t that came out was disgusting!!
Hope it helps!
Hope it helps!
kam-325i
- Contact:
If its running rough when warm, have a look at the Blue engine temp sensor......
