Water pump issues
klu99apm
Wed Dec 17, 2008 4:07 pm
I'm trying to replace my water pump on my '88 325 touring and have got one from GSF which looks like the one in the parts diagram below:
Trouble is my old pump only has one 'exit', and the new one has two. The GSF description for the one i have is 'E30 325i 88>91 M20'. Is the correct one 'E30 325i 85>88 M20 BQ??
Any help much appreciated!
stonesie
Wed Dec 17, 2008 4:13 pm
The twin exit pump is the early one and the single is the later type, which you need.
Maby it's been boxed wrong but it needs exchanging for a single exit pump with a metal impeller if possible...
klu99apm
Wed Dec 17, 2008 4:15 pm
Thanks for the advice. I'll have to swop it!
Wed Dec 17, 2008 6:44 pm
they have just made an assumption on the wrong part, 1988 being a changeover year, I had exactly the same issue when I bought a pump from my local motorfactors. Only realised the difference when I went to fit the new pump, it was late, i was fed up, so the old one went back on :D :P :P
klu99apm
Wed Dec 17, 2008 7:32 pm
E30BeemerLad wrote:Only realised the difference when I went to fit the new pump
Unfortunately I didn't look closely at the two and had fitted the new one before I realised they were different! Never mind - i'll swop them tomorrow!
bmwscorpion
Wed Dec 17, 2008 9:02 pm
On a slightly different note the additional pipe for the earlier car, where does this go to, I have this type pump on a 2.7 eta with a later e30 type rad, the smaller hose is blanked off, would this cause problems.?
Any advice appreciated..
Alan
stonesie
Wed Dec 17, 2008 9:12 pm
IIRC on the pre-facelift cars it goes to the coolant bottle, the smaller outlet being blanked off shouldnt cause any issues if the rest of the system is facelift with the coolant bottle on the N/S wing.
Saying that it's not ideal either.
bmwscorpion
Fri Dec 26, 2008 8:37 pm
Thanks for the info, ..
Does any body know if the later pump will replace the earlier type pump without problems..?
Thanks for your help.
Fri Dec 26, 2008 10:07 pm
The later pump is a direct replacement for the early one, assuming the rest of the cooling system is the later type as well.
GSF is at fault (there's something novel!), since no touring of any age had the early pump
bmwscorpion
Sat Dec 27, 2008 10:50 am
Thanks for the Info Brian....
Much appreciated.
