3 & 6 wire throttle position sensor differences
Posted: Sun Dec 07, 2008 1:51 pm
by no2lurch
on my 325i i have a 6 wire TPS, but on my new loom, i have a 3 wire TPS plug.
whats the difference between the TPS's apart form the number of wires?
and more importantly, how can i get it to work? can i slice the old plug onto the replacement loom, or do i need to replace the TPS too?
Re: 3 & 6 wire throttle position sensor differences
Posted: Sun Dec 07, 2008 2:30 pm
by no2lurch
apparently the 6 wire one i have now is from when the car was an auto, but the 3 wire one is for a manual.
do i need to change the ecu though now? are auto and manual ecus the same? my current ecu is a 173 one. this ok?
Posted: Sun Dec 07, 2008 11:53 pm
by Brianmoooore
ECU is fine. 6 wire TPS is the same as the 3 wire, but with another switch added on for the switchable auto box.
You either need to change the TPS for a manual one, or splice the 6 wire plug onto your new loom.
Posted: Mon Dec 08, 2008 3:54 pm
by mirage
i have the same problem.my car is switchable auto and im planning to swap for manual.can i use the same loom and 6 wire tps or do i need to change it?any disadvantage?
Posted: Mon Dec 08, 2008 6:47 pm
by Brianmoooore
mirage wrote:i have the same problem.my car is switchable auto and im planning to swap for manual.can i use the same loom and 6 wire tps or do i need to change it?any disadvantage?
Only problem you're ever likely to have with using the auto engine loom and TPS, is if you ever need a replacement TPS, when you'll be restricted to the much rarer six pin type.
Posted: Tue Dec 09, 2008 12:01 am
by mirage
I C.....thanks mate....
