Box above ecu
Posted: Fri Oct 31, 2008 7:19 pm
by Danny-C
Hi all does anyone know what the box above the ecu does its screwed to the plate that holds the ecu up. thanks .
Re: Box above ecu
Posted: Fri Oct 31, 2008 7:34 pm
by BMW_3xx_i
325e model ?
Re: Box above ecu
Posted: Fri Oct 31, 2008 7:36 pm
by Chris-W
OBC relay box, I'd say.
Re: Box above ecu
Posted: Fri Oct 31, 2008 7:43 pm
by Danny-C
It is a e30 325i 88 model and what does it do im problem solving and wondered what it was thanks
Re: Box above ecu
Posted: Fri Oct 31, 2008 7:44 pm
by Chris-W
Is it black?
Re: Box above ecu
Posted: Fri Oct 31, 2008 7:47 pm
by Danny-C
I think so its only got a few wires bout 5 going in to it. my car has a no spark problem and was changing ecu and noticed it and never seen it, is it for the computer?
Re: Box above ecu
Posted: Fri Oct 31, 2008 7:56 pm
by BMW_3xx_i
can you upload a photo of this box ?
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:01 pm
by Danny-C
not at the mo the car is down mates garage but will try if not sure what it is? :mad:
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:04 pm
by Chris-W
Does it look like this?
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:10 pm
by BMW_3xx_i
I've seen this box only in 325e (2,7l 125-h.p.) Motronic 1.0
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:16 pm
by Danny-C
Yes i think it does look like that yes what is it is it for the computer, and it is a 325ise model
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:20 pm
by BMW_3xx_i
it manages an idle control
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:24 pm
by Danny-C
doesnt have anything to do with the spark then have changed most of the other things that do. thanks
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:25 pm
by magpie
excellent read guys,,,,it's not that then [no spark] crank sensor?
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:32 pm
by Danny-C
Na done crank sensor, pulse sensor, ecu, dizz, rotor, coil, leads, plugs, earths, u name the norm ive tried it.
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:43 pm
by magpie
not good m8 did the bits you change come off a running car???? 8)
Re: Box above ecu
Posted: Fri Oct 31, 2008 8:48 pm
by Speedtouch
Just a thought, does your car have an OBC, because it has a CODE function (immobiliser) that can be used to cut the ignition - if it's playing up, it could be causing your problem.
I'd also suggest ensuring that the ECU is getting a firm +12V feed from the ignition switch - if the switch is worn out, it could be causing an intermittent supply.
Re: Box above ecu
Posted: Sat Nov 01, 2008 8:47 am
by Danny-C
That sounds good how do i test the ecu is getting a good 12v cause it is a intermittent fault somethimes it works and somethimes nothing.
Yes it does have the OBC but never seen the code bit come up how could i resolve that can i just change the OBC ecu box that manages it.
Magpie all parts are off a working car and have also had it plugged into the bmw fault finder still nothing.
Thanks guys
Re: Box above ecu
Posted: Sat Nov 01, 2008 9:28 am
by Brianmoooore
Connect a piece of wire between the + terminal on the coil and the phantom battery + terminal on the bulkhead (without disconnecting anything), and see if the car will start.
Box is part of the OBC and nothing to do with idle control.
Re: Box above ecu
Posted: Sat Nov 01, 2008 11:53 am
by Danny-C
Hi Brianmoooore i tried that wire between coil and + battery and it did seem to make a difference what is the next step in sorting that out
Re: Box above ecu
Posted: Sat Nov 01, 2008 12:02 pm
by Speedtouch
The +12V is supplied to pins 18 and 37 of the 55-pin Motronic connector according to this diagram http://www.autolib.diakom.ru/CAR/BMW/19 ... /fig02.pdf
You could unplug the ECU and test for a reliable +12V feed to these pins using a multimeter or test lamp. Don't forget, although pin 18 is permanent +12V, pin 37 is ignition switched, so will only activate when your ignition key is turned to the appropriate position(s).
Re: Box above ecu
Posted: Sat Nov 01, 2008 1:30 pm
by Brianmoooore
Danny-C wrote:Hi Brianmoooore i tried that wire between coil and + battery and it did seem to make a difference what is the next step in sorting that out
What do you mean by "it made a difference"?
Did it start or not?
Re: Box above ecu
Posted: Sat Nov 01, 2008 1:38 pm
by Danny-C
Yes it did start but it has been starting again now but runninng rough but was a lot better when the 12v coil was connected to the main 12v+
Re: Box above ecu
Posted: Sat Nov 01, 2008 1:56 pm
by Brianmoooore
The next time it won't start, connect up the battery to coil lead again and see if it starts.
For intermittent and poor running, the DME (white) relay is suspect.
Re: Box above ecu
Posted: Sat Nov 01, 2008 2:16 pm
by Danny-C
I can turn the car over and it doesnt start or if it does it cuts out then whilst turning put a live to the coil and it will fire straight away. will check dme now
Re: Box above ecu
Posted: Sat Nov 01, 2008 2:23 pm
by Danny-C
Tried changing the relay doesnt make a difference so just to reiterate turning car over nothing happens keep turning and put a 12+ to the coil and she starts up straight away different relay didnt work. :x :x
Re: Box above ecu
Posted: Sat Nov 01, 2008 4:00 pm
by Brianmoooore
If connecting the battery+ to coil + wire makes a difference, then remove the panel above the glovebox and find a two pin connector hanging from the loom above with two green wires going to it (one to each pin). Disconnect the plug that goes into it, and search around the loom nearby for an identical plug doing nothing.
This plug will have a loop of green wire connected to it and just be tied up to the loom. Pull it free and push it into the socket, so connecting the two green wires from the loom together.
If the spare plug isn't there, use the one that's already plugged into it, and short the wires together.
Re: Box above ecu
Posted: Sat Nov 01, 2008 4:06 pm
by Danny-C
ok will check that now what is that doing/ connected to.
Re: Box above ecu
Posted: Sat Nov 01, 2008 6:07 pm
by Danny-C
your a legend i think that has done it it seems to be better now. The test will be when i go back to it and see if it will start again, Will let you know how i get on many thanks again dan. :P :P
Re: Box above ecu
Posted: Sun Nov 02, 2008 1:37 pm
by h2700
[quote="Speedtouch"]Just a thought, does your car have an OBC, because it has a CODE function (immobiliser) that can be used to cut the ignition - if it's playing up, it could be causing your problem.
do u know anything more about this ? i have a similar problem and i believe this is my problem lol
Re: Box above ecu
Posted: Sun Nov 02, 2008 2:57 pm
by Danny-C
I dont know if this is the problem. what are your symptoms. But if it is the same i think ive fixed mine. with that wire trick that Brianmoooore said about but not sure excatly what that does.
Re: Box above ecu
Posted: Sun Nov 02, 2008 3:02 pm
by h2700
just done the same thing to mine and sorted it think the obc unit has packed in
Re: Box above ecu
Posted: Sun Nov 02, 2008 3:09 pm
by Danny-C
what was your car doing
Re: Box above ecu
Posted: Sun Nov 02, 2008 3:45 pm
by h2700
just put a 2.7in . tryed to start it and it would turn over but there was no power at the coil so there was no spark so it wouldnt start ,
checked the ecu and found there was no ignition live onto to the ecu (pin27) followed that back and found that the was power on one side of that white plug and no power on the other side , followed that plug back to the relay box for the obc , im guessing the obc code function has either enabeled or that because the cars been sat in bits for quiet a while its reset itself or sumit ?
mines running ok i think now not tested it as im waiting for a chip from ant, as the one i had originally from ebay was a fake i think :?
Re: Box above ecu
Posted: Sun Nov 02, 2008 4:00 pm
by Danny-C
nice on mine been giving me trouble for 2 months now been getting worse hopefull now sorted
