Water in passenger side footwell
Posted: Thu Oct 30, 2008 3:11 pm
by Rkive
Just noticed when cleaning my car, under the mat on the passenger side footwell is a damp patch of water.
Anyone familiar with this problem? as I cannot figure out where it is coming from.
Re: Water in passenger side footwell
Posted: Thu Oct 30, 2008 3:21 pm
by beemerbird
Have a look at the 'Rust, Water in footwell' thread below yours. You may find this helps
Posted: Thu Oct 30, 2008 4:20 pm
by fingerman
Very popular problem (have it myself!) - do a quick search and all will be revealed
You'll probably end up taking your carpets out to have a good look
Posted: Thu Oct 30, 2008 8:34 pm
by robbo86
Going to post jack here
are there any common fault (besides elephants trunk as I cleaned that out allready) for a swimming pool in the drivers footwell
Posted: Thu Oct 30, 2008 8:45 pm
by cro320
you should post a question: anyone with no water in footwels?
I would suggest cleaning sunroof drains but I don't think you leave opened sunroof on rainy day
Re:
Posted: Thu Oct 30, 2008 9:02 pm
by jon_d_h
Can you see where the water is coming from? Is it coming from the bulkhead or is it coming down the side by the speaker?
Re:
Posted: Thu Oct 30, 2008 9:08 pm
by robbo86
I cant really, the swimming pool is there by the time I come to my car. Someone did suggest drying the floor and sprkinling talc to try and see where its tracking in from as my carpets are already out so they dont get mouldy and smell. Trouble is the paint on my floorpan looks minty mint so its sometimes hard to tell wether its just good paint or wet good paint.
By bulkhead iw ould assume you mean firewall? How might it be getting in from down by the speaker?
Re:
Posted: Thu Oct 30, 2008 9:16 pm
by Speedtouch
Have you tried removing the front wheelarch liner and looking at the state of the front end of the sills/floorpan?
This is the crap I've just had to sort out (on both sides);
Re:
Posted: Thu Oct 30, 2008 9:24 pm
by jon_d_h
By the speaker means it could be coming from the roof or sun roof drains. If you tip water into your grill on your scuttle on the passanger side and then get in your car and watch where it is coming from. That is what I have been doing with mine. I have removed the carpet, centre consol and glove box on the passanger side of mine. I have now noticed that the leak is coming through the gasket for the heater matrix so I am going to remove the dash this week end to sort it.
Re:
Posted: Thu Oct 30, 2008 9:27 pm
by robbo86
I meant to say i have had my sunroof drains lasted out with an airline and was told they were fine. So I am out of ideas
Re:
Posted: Thu Oct 30, 2008 9:40 pm
by jon_d_h
Is the elepant trunk blocked? What happens when you tip water into the passanger side grill? Does water come through from up behined the glove box?
Re:
Posted: Thu Oct 30, 2008 10:55 pm
by robbo86
Cleaned 18 years of accumulated crap out of my elephants trunk, still hasnt solved the prolem. i thought the elephants trunk.
Not tried that, the water is drivers footwell for me!!!
Re:
Posted: Fri Oct 31, 2008 11:07 am
by jon_d_h
Its in the drivers foot well for me too. Its coming through the heater matrix when I tip water in the grill so I am going to change the gasket for it. You really need to tip water through the grill and watch where it is dripping down into the footwell.
Re:
Posted: Fri Oct 31, 2008 11:15 am
by jbh
mines is a hole in the front battery tray
but soon to be fixed as i just cut a battery tray out a breaker
Re:
Posted: Tue Nov 11, 2008 2:12 pm
by Nay
wazza, weasleys got this problem too! Found it the other day when putting on his seat covers.
Re:
Posted: Tue Nov 11, 2008 4:20 pm
by Black_Potato
Mine was a leaking heater matrix
Posted: Wed Nov 12, 2008 12:09 am
by alpinac227
I have same issue - but have noticed hissing steam and rusty water on beige carpet. Ripping carpet out and looking to replace heater matrix. Last item left to replace in cooling circuit. Anyone know cost and procedure or links to instructions.. Ta PS it's an Alpina C2 2.7i (grin grin :-))
Posted: Wed Nov 12, 2008 12:13 am
by bss325i
alpinac227 wrote: Ta PS it's an Alpina C2 2.7i (grin grin
Got any pics of the C2?
Re:
Posted: Wed Nov 12, 2008 10:55 pm
by alpinac227
Nopt at mo but it's in Alpina Green and original
Re:
Posted: Thu Nov 13, 2008 12:55 am
by bss325i
alpinac227 wrote:Nopt at mo but it's in Alpina Green and original
Pm sent
Re:
Posted: Fri Nov 14, 2008 10:13 pm
by bene30jane
mine was heater matrix, leaking at the control valve, about £150 for new part i think, also had rain water blown through passenger door rubber seal on wet windy days, took a while to find that....
Re:
Posted: Fri Nov 14, 2008 10:23 pm
by madaboutthe30
Its worthwhile you take out ur carpets, and while you do that make sure you waxoyl it.
With me it came from above the glove compartment, through the lining of the wheel arch as someone said
Re:
Posted: Sat Nov 15, 2008 2:16 am
by robbo86
AAAARRGHHHHH this is driving me up the bloody wall. Car has been stood for about 1 week, came out to the car and rear passenger footwell, where all the water collects becuase its the lowest part of the car and the carpet is out, was about 3 inches deep.
Its embarassing when my mates get in now
