Gauges move up after turning engine off!!?
Posted: Wed Oct 22, 2008 11:10 pm
by wildeian
When I turn the engine off in my 325i Touring, the Rev counter creeps up to 1000 rpm, and the mpg swings over to 30-40 mpg!!
Have I got a Ghostrider, or is it sign of impending doom!??
Cheers, Ian
Re: Gauges move up after turning engine off!!?
Posted: Thu Oct 23, 2008 10:38 pm
by wildeian
nobody??
Posted: Fri Oct 24, 2008 7:42 am
by mrLEE30
never heard of this before....i can only think its a symptom of dead or dying SI batteries why not change em and see if it still does it?
Posted: Fri Oct 24, 2008 9:14 am
by Brianmoooore
The version of the SI board with lithium batteries (not normally known for causing problems when/if they go flat) is known for developing a minor fault in the form of a 'kick' in the rev counter, shortly after the ignition is turned off. It's possible that your problem could be an extension of this.
Either way, it's likely to be SI board related, whether you have the NiCd version or the lithium.
Posted: Fri Oct 24, 2008 10:44 am
by no2lurch
i get the kick!
Posted: Fri Oct 24, 2008 2:29 pm
by wildeian
Thanks guys, need a new set of clocks anyway to match the engine mileage!!
Posted: Fri Oct 24, 2008 4:50 pm
by Brianmoooore
Odometer is easily changed to whatever mileage you want (and frequently has been!)
Posted: Fri Oct 24, 2008 5:47 pm
by StuBeeDoo
Brianmoooore wrote:The version of the SI board with lithium batteries (not normally known for causing problems when/if they go flat) is known for developing a minor fault in the form of a 'kick' in the rev counter, shortly after the ignition is turned off. It's possible that your problem could be an extension of this.
Mine has kicked for the entire 4 years I've had the car. A few weeks ago to did stick at 1k rpm a couple of times.
Good to know I'm not the only one.
Posted: Fri Oct 24, 2008 5:51 pm
by Eddie25
StuBeeDoo wrote:Brianmoooore wrote:The version of the SI board with lithium batteries (not normally known for causing problems when/if they go flat) is known for developing a minor fault in the form of a 'kick' in the rev counter, shortly after the ignition is turned off. It's possible that your problem could be an extension of this.
+1 I did once hear there is no such thing as an economical BMW. But i thought 30 mpg whilst the car was sat on the drive and the keys in my pocket was a tad unfair.
Posted: Fri Oct 24, 2008 7:21 pm
by Brianmoooore
Hmm! It's beginning to look like the lithium powered version of the SI board isn't as trouble free as I thought it was!
Posted: Fri Oct 24, 2008 7:29 pm
by Nick325
My old 1988,325 kicked every time i turned the engine off.I had the car for 5 years,i'd even changed the SI Batteries.Never had a problem.
My new 87 325 Cab does the same thing.I don't think its anything to worry about.
Nick
Re:
Posted: Sat Nov 22, 2008 1:13 am
by bene30jane
how do you change these as mine has done this for about 2 years!!!.... i thought it was some wrong with the clocks....
Re:
Posted: Sat Nov 22, 2008 1:29 am
by maggspower
Both of mine have done this, never had any problems with either
