Petrol Leak
Posted: Tue Oct 21, 2008 10:07 am
by tommtb
Hi
i have a very minor petrol leak on a 325i coupe
its more of a seeping of petrol from the area where the pipe is clipped to the tank, most likely just the clip.
is this easilly accessed to adjust the clip?
worst case how much am i looking at for a new tank?
cheers everyone who can help
Re: Petrol Leak
Posted: Tue Oct 21, 2008 10:13 am
by SPADGE
It'll almost certainly be the tank itself as they rot on the pipe where the rubber one connects or by the seam.
A new tank from gsf/euro's is around 90 quid.
Re: Petrol Leak
Posted: Tue Oct 21, 2008 12:23 pm
by tommtb
ok mate grand, the leak seemed to come from right where the pipe joins to the tank, just around the clip...
so maybe the take has gone rotted where the pipe attaches if thats what you meant?
cheers for the price too, any websites? any idea of fitting costs or times?
Re: Petrol Leak
Posted: Tue Oct 21, 2008 12:27 pm
by Fushion_Julz
To fit the tank you need to drop the exhaust and remove the propshaft....
I'd reckon, if you have access to a ramp or pit, then about 3-4hrs should do the job...
However, it would be well worth either changing or at least cleaning and greasing the brake pipes while you're at it as they really need the tank out to be replaced and are likely to need doing in any case....
Not a job I'd fancy doing on the drive, but probably possible...add a couple of hours at least, though.
Re: Petrol Leak
Posted: Tue Oct 21, 2008 12:41 pm
by daimlerman
Tank it's self is only held by 5 bolts,it's the rest of the stuff that has to come off that's the problem...there are two access hatches under the rear seat cushion,both have wiring connections under,and the wires are NOT long enough to enable the tank to reach ground level
also worth changing the fuel filter whilst you have the thing in your hand.Job took me half a day,working off the ground.
Re: Petrol Leak
Posted: Tue Oct 21, 2008 1:09 pm
by tommtb
ok great information thanks
i wont be doing the work myself as ive got no clue what im doing and no access to a ramp or a pit and generally would make a balls up!
any idea of cost and time for a garage to do it? 3-4 hours doesnt sound too bad?
Re: Petrol Leak
Posted: Tue Oct 21, 2008 1:16 pm
by E30BeemerLad
for the tank try GSF as suggested
www.gsfcarparts.com
there are 2 sizes of tank, depending on what your car is.
Re: Petrol Leak
Posted: Tue Oct 21, 2008 1:24 pm
by tommtb
ta mate, as always mine is the most expensive one!
not as much as the BMW part though obviously, so thats sweet.
Re: Petrol Leak
Posted: Tue Oct 21, 2008 1:53 pm
by tommtb
no ideas for a fitting price at a garage?
Re: Petrol Leak
Posted: Tue Oct 21, 2008 2:17 pm
by Fushion_Julz
depends on where you are and how much your local wrench monkies charge....
Main dealers are around the £100-120 per hour mark, a decent and knowledgeable independant about £70/hr and the back street bodge merchant maybe around £50/hr...
However you a) get what you pay for and b) will pay more *hours* to a person or garage who have no idea what they are doing and are "learning the job"...
Where do you live?
Re: Petrol Leak
Posted: Tue Oct 21, 2008 2:44 pm
by tommtb
im finding out for someone in south london, london bridge area...
but he doesnt mind travelling a few miles out of London
Re: Petrol Leak
Posted: Tue Oct 21, 2008 3:08 pm
by Fushion_Julz
I'd recommend MJF Engineering in Beare Green nr Dorking...
Mark knows his stuff and is pretty cheap and efficient
Re: Petrol Leak
Posted: Tue Oct 21, 2008 3:32 pm
by tommtb
thanks for the help!
Re: Petrol Leak
Posted: Tue Oct 21, 2008 11:03 pm
by Brianmoooore
Loosen off the clips at both end of the hose, turn it to free it up, then push it tight up against the tank and position the clip so that it is only about 2 - 3mm from the tank.
If the hole is in the stub pipe, you may get lucky and seal the leak.
Don't blame me if the whole stub disintegrates though!
