Clutch pedal and fluid problem
Posted: Sun Oct 12, 2008 9:43 pm
Took my 325is for a good blast Friday night everything was fine.
Came to drive it Saturday morning and the clutch pedal had I lot of free play and the biting point was very low down. I checked the clutch fluid and It had reached minimum toped it up gave the pedal a good pump, took it out for a drive 5miles it was fine again.
Didn’t use the car until today, have been to busy to have a look to see what the problem is. But the same happened again, clutch pedal had I lot of free play and the biting point was very low down. I checked the fluid and It had reached minimum toped it up gave the pedal a good pump, took it for a drive and it’s been fine. I will jack it up tomorrow and have a look underneath.
Am I right by thinking that it could be the clutch slave cylinder leaking slightly? Has any one had the same problem before?
I think I might as well order one any way don’t thing it’s ever been changed.
I did change the fluid on the service I gave it two weeks ago.
Thanks JayB
Thanks JayB
