elec window switch lights stay on
Posted: Sun Oct 12, 2008 2:43 pm
by sohood
the lights on the electric window switches stay on all the time in my cabrio, causing my battery to drain..
any ideas on where to start looking to fix this?
Re: elec window switch lights stay on
Posted: Sun Oct 12, 2008 2:53 pm
by mrLEE30
check the door light switches, the system works with ignition on or doors open so if you have a bad contact the system may think the doors are always open and thus stay on.
check both doors, there are two wires one for the interior lights the other for the windows..
mrlee
Posted: Sun Oct 12, 2008 11:50 pm
by Brianmoooore
First of all, pull out fuse 28 to confirm that the power is coming from where it should, as it's just possible that the fault could be connected to the unloader relays.
Posted: Wed Oct 15, 2008 6:02 pm
by sohood
pulled out fuse 28, lights go out..so i guess that means power is coming through the right place?
by sohood
oh and i changed all the relays for spares i had and it didnt make a difference
Posted: Wed Oct 15, 2008 7:07 pm
by Jonesy1968
is your interior light on too? I had some work done on my cabby and they forgot to put the little door plug back on which turns the interior lights and the elec windows lights off when you close the door...
Posted: Wed Oct 15, 2008 10:31 pm
by Brianmoooore
If fuse 28 puts the lights out, the power is coming from where it should, so it can't possibly be anything to do with the unloaders.
Take the panel above the glovebox off, and find a (usually) blue relay in the front left corner of the space revealed. This relay (a changeover type) is either faulty, or (more likely) being held on by a faulty door pin switch, or a short to earth of one of the wires to them.
Posted: Fri Oct 17, 2008 3:40 pm
by sohood
Brianmoooore! ur a genius! it was the doorpin switch messing around, put another one on and its fine! many thanks for the help!
