Rattling from front of engine
Posted: Mon Oct 06, 2008 7:30 pm
by sk712
Hi there,
Just hoping if someone could help me out. I had a rattling noise coming from the front of my M20 and was sure it was the altenator as it soon died after this rattle appeared. I replaced it with a reconditioned altenator and the rattle was gone when I started the car but when it reappeared once the engine got up to temperature. It definately sounds like it is coming from the alternator area. I did put a screwdriver on the altenator to listen for anything strange and it seems to be humming away fine. Just wondering if there is something else that could be causing it or is the reconditioned alternator a dud? The water pump was replaced about a year ago. Any suggestions would be greatly appreciated.
Cheers.
Re: Rattling from front of engine
Posted: Mon Oct 06, 2008 7:44 pm
by stonesie
If it was a cheaper water pump it could be dying already, it could also be the viscus unit that's on the front of the waterpump.
Run it upto temperature so the viscus locks and see if that makes a differance to the noise, all the air moveing might mask it though so check for play in the fan too (with the engine off).
Posted: Mon Oct 06, 2008 8:02 pm
by bm_boy
id second the waterpump mate, usually the impellor breaking down and rattling about, will get worse the more you drive, does it overheat or has it overheated since the rattle started sounding? if so it could be the waterpump.
Posted: Sat Oct 25, 2008 3:04 pm
by sk712
No it hasn't overheated & the water pump is only a year old. I'll replace it if that's the only possibility I suppose.
Posted: Sat Oct 25, 2008 7:55 pm
by cro320
check timing belt adjuster, had the same problem...also worn alternator bearings can make sound like that
Re:
Posted: Sun Oct 26, 2008 1:13 pm
by E30Gheko
I had a strange rattle coming from mine and found that one of the fan blades was catching a coolant hose ever so slightly. :D
Re:
Posted: Sun Oct 26, 2008 2:00 pm
by sk712
Thanks for the replies lads. The noise only occurs when the engine is fully warmed up. Its a consistent turning noises kind of chinging sound if that helps. The fan blades aren't catching anything.
