red exclamation mark on
Posted: Mon Sep 15, 2008 6:36 pm
by mhuk
I bleed my brakes again today and now I have the red exclamation mark on all the time.
To me that means the hand brake is pulled up but it's now. Does it mean something else? I was doing some sliding also
Re: red exclamation mark on
Posted: Mon Sep 15, 2008 6:50 pm
by stonesie
Low brake fluid? maby the float is stuck or the wireing not connected properly?
Posted: Mon Sep 15, 2008 6:52 pm
by scotttollan
i could also mean brake pad wear that's if you have done them of course
Posted: Mon Sep 15, 2008 7:16 pm
by stonesie
I thought that was a seperate light, a circle with dashed brackets around it to indicate brake lineings/pads?
Posted: Mon Sep 15, 2008 7:21 pm
by Brianmoooore
The red light with the exclamation mark is for low fluid level in the resevoir. Nothing to do with handbrakes or pad wear.
Posted: Mon Sep 15, 2008 10:01 pm
by scotttollan
oh right sorry
Posted: Mon Sep 15, 2008 10:26 pm
by mhuk
Thanks, I'll take a look before going to work
Posted: Tue Sep 16, 2008 10:48 am
by mhuk
Brianmoooore wrote:The red light with the exclamation mark is for low fluid level in the resevoir. Nothing to do with handbrakes or pad wear.
Water right?
It was low and i filled it up and now the light is on and off like a yoyo
ALso the brake fluid was low so I topped it up (more on that later)
Posted: Tue Sep 16, 2008 1:36 pm
by Brianmoooore
mhuk wrote:Brianmoooore wrote:The red light with the exclamation mark is for low fluid level in the resevoir. Nothing to do with handbrakes or pad wear.
Water right?
No!! Brake fluid level.
Low coolant light is in the panel in the roof.
