Thanks and new questions!
Posted: Sat Aug 23, 2008 7:48 am
by tannerman8807
Sorry guys internet off last night, im stripping the hub of the front strut, there is a large nut, what size is it as need to but one. must be 38-45mm range.
Help as off to shop at 8.30 then i lose the wifes car!!!!
Re: Sorry urgent question need answer before 8.30
Posted: Sat Aug 23, 2008 8:07 am
by beardymat
its either a 36 or 34mm. i got caught short at work the other week doing mine and had to grind down the wall on my 36mm impact socket so it would fit inside the hub. you shouldnt have that problem with a standard socket.
sorry i cant be more exact but with the socket being a tight fit into the hub i couldnt tell if it was the correct size but i didnt check at the time as i didnt care as it did the job.
just had an idea, ill be back
Posted: Sat Aug 23, 2008 8:09 am
by tannerman8807
Waiting thanks
Posted: Sat Aug 23, 2008 8:12 am
by beardymat
damn, idea no good
sometimes on realoem it gives sizes on nuts and bolts, nothing on the hub nut though.
Posted: Sat Aug 23, 2008 8:14 am
by tannerman8807
Thanks anyway, ill take a plastacin mould to the shop
Posted: Sat Aug 23, 2008 8:22 am
by ric325i
36
Posted: Sat Aug 23, 2008 8:24 am
by ric325i
just been out to teh garage in my jim jams with my breakfast getting soggy to find teh socket i used for teh job over a year ago.
for teh hub nut im 90% sure its a 36 as its teh same size as teh drift shaft hub nut on a 5turbo.
90% it was a year ago! hope this helps? now to my soggy crunchy nut
Posted: Sat Aug 23, 2008 8:28 am
by tannerman8807
Ta
Posted: Sun Aug 24, 2008 10:01 am
by tannerman8807
Thanks chaps it was a 36 and my dad had one, so saved lots of dosh there. What a job though, after removing nut and pulling off hub the bearing fell apart leaving the rear case still on the spindle. Is this normal? happend both sides. Is it easy to get back together? When i took of the rears a while ago hade to buy new bearing complete.
I am also replacing everything rubber , so new wichbone mounts srop links etc. can wait to see how she handles. Whats the best way to get the wishbone mounts in the bracket?
Posted: Sun Aug 24, 2008 11:13 am
by beardymat
the bearings will fall apart and its good practice to replace them. mine came apart but as it was a sunday and i was replacing the disc back plates on a whim i retrieved all the parts, cleaned them and regreased them with some high temp grease and put them back together. the rear part needs to be pulled off the stub axle and refitted to the bearing. mine has been fine since by the way
the rear wishbone mount fits into the lolipop mounted to the underside and these can be pressesd in using a vice, they are a bugger to fit to the wishbone itself but most people use fairy liquid to fit them. dont use wd40 or such like as the bushes need to dry out to work properly.
