swapping E30M42/E36M42 Engine parts
Posted: Tue Aug 12, 2008 6:55 pm
by EasyM5
:bmw: Hi i have just bought a 1990 E30 M42 318is with 8 bent exhaust valves and the timing chain idler cog ripped out of the engine casting
I have managed to buy a E36 M42 318is engine i know the whole inlet manifold side and the sump have to be changed over also the p/steering/alternator and crankshaft pulleys
I am wondering if there is anything else needs to be changed/adapted so if anyone has done this engine swap any advice would be much appreciated
Re: swapping E30M42/E36M42 Engine parts
Posted: Tue Aug 12, 2008 8:23 pm
by monkey
e36 m42 and e30 m42 have different exhaust manifolds so that will need changing along with the cam cover as the oil breather is in a different place and the oil dip stick . the engine mounts i think are different too
Posted: Wed Aug 13, 2008 1:47 pm
by EasyM5
Hi i am a bit confused as all the exhaust studs seem to line up ok with my original exhaust headers ?
But thanks for the reply
Posted: Thu Aug 14, 2008 7:19 pm
by monkey
the right hand drive ones that i have seen have different exhaust manifolds i tryed to fit an e30 one to an e36 and it hit the steering colum so i had to mod the manifold as i didnt have an e36 one . an e36 one may fit an e30 but design of the pipe are different an e36 one may even give you more room around the steering joint
Posted: Fri Aug 15, 2008 6:33 pm
by EasyM5
Hi what sort of mod did you make is it an easy bash it with a hammer or was welding involved
I have dropped the engine back in now (the complete exhaust has not been removed from car) it seems to line up ok but i have not pushed it onto studs yet and tightened it up but it does seem tight around steering though will try after weekend as missus wont let me into garage till monday :bmw:
Posted: Fri Aug 15, 2008 8:56 pm
by monkey
i had to cut and shorten the e30 on to fit in an e36 it was a fair bit if yours is in the engine bay and clears then all is well . you may have more luck than me as you are putting an e36 one in an e30 :)
Posted: Sat Aug 16, 2008 10:44 am
by dannyboy759
Just fit the whole e36 engine instead! job done
Posted: Mon Aug 18, 2008 8:04 pm
by EasyM5
monkey wrote:i had to cut and shorten the e30 on to fit in an e36 it was a fair bit if yours is in the engine bay and clears then all is well . you may have more luck than me as you are putting an e36 one in an e30 :)
Hi no i am using the E30M42 one it wasnt removed when i took the old engine out it took a bit of wrangling had to loosen back end of exhaust but it bolted straight onto E36M42 head studs{ to my relief )they must differ year to year anyway she fired up first time so i am well chuffed
Thanks for your help :bmw:
