power steering conversion and cambelt advice
Posted: Mon Aug 11, 2008 3:33 pm
by dan_cup
Hello, im a newbie and this is my first post so be gentle!! :D
ive just got myself a 1987 320i saloon in alpine white.
shes bit rough round the edges but not bad for 121k.
anyway i was wondering is it possible to convert it to power steering and if so wheres the best place to be getting the parts i need?
also ive just bought and cambelt and im going to give this a go. is it a major job?
im going to have a search through to forum but just asking the question for now.
im also looking for a lip spolier for the boot and whether the fog lights are a generic size, if anyone could help with that also. thanks
Dan :cool:
Re: power steering conversion and cambelt advice
Posted: Mon Aug 11, 2008 3:56 pm
by eamo
yes it is. all parts are readily available and come up for sale quite often in the for sale section. all you need is the rack (your own tie rods will do) ps belt, ps pump and bracket, ps reservoir and hoses
its not too bad - depends on what your like with a spanner. if i were you id replace the tensioner and water pump while your at it as well.
again check the for sale section - these come up from time to time as well. you'll need the pre face lift fogs for your car as yours is a chrome bumper model. the wire to connect into the back of them is already there. all you need after that is the switch and relay number k8
by aboard!
Posted: Mon Aug 11, 2008 4:02 pm
by Dave_M3
For the steering, you'll need the PAS rack, pump, resivoir and steering column U-Joint coupling and of course a new belt to drive the pump
Easy enough to fit, just a case of bolting the stuff on.
Best place to look would be a scrapies nearby or ask in the wanted section here since somebody will surely have it or maybe Spadge or Chris-W on here might have everything you need to convert it :wink:
Could also put an e36 or E46 rack in while your at it but it's a little bit more work and costs a abit more however the improvement in steering and feel is worth it.
Cambelt on an M20 is an easy enough, Rad, fan, waterpump hosing, and pulleys have to come off to get the timing covers off alright and it's nearly easier to take the bonnet off for space and ease of access but the job is far from complicated. Change the stat and waterpump while you are in there too
Loads of threads and guides on here floating about anyway on it.
Also try the wanted section for the lip spoiler and fogs :wink:
The Fogs are different for the pre-facelift and facelift cars alright, The first having square shaped ones and the later having ones that are curved at one side
***EDIT***
Arrrgh
beat me to it, Eamo :D
Posted: Mon Aug 11, 2008 4:03 pm
by FlappySocks
Get a E36 rack or better still a Z3 rack. Standard racks are disappointing.
Posted: Mon Aug 11, 2008 4:47 pm
by dan_cup
thanks for the rapid response guys, take it the water pump and stat can be got from local motor factor places?
im quite competant with the spanner i have changed cambelts on other cars before.
how much extra work is the E36 rack? i dont want to be throwing too much money at the car.
Posted: Mon Aug 11, 2008 4:58 pm
by FlappySocks
Plenty of info on E36/Z3 if you search. No extra work in your case, except in getting the bits you need, which may cost a bit more. It does transform the steering, particularly a Z3 rack.
Posted: Mon Aug 11, 2008 5:53 pm
by dan_cup
ive found a power steering package for £50, i presume this is a good price?
Posted: Mon Aug 11, 2008 6:59 pm
by Dave_M3
Yep, that's a good price alright :)
E36 racks go for abit more just on they're own and you then need to get the bits to make it fit. I know what you mean about not wanting to throw too much money at the car, May be better to just put in the E30 PAS rack and see how it goes since you can't go wrong for 50 quid if the pump is a good one.
The bad thing about the E30 rack is it's very slow as in around 4 turns lock to lock,
The E36 racks are around 3.4 which means steering input is far less and plus the racks are usually in better nick since they are newer
E46 racks are abit better still being newer again.
Z3 racks are then only 2.7 turns which totally transforms the car but they are really hard to find
Posted: Mon Aug 11, 2008 7:44 pm
by dan_cup
ah right very good now i understand why they are a better rack,
the only reason im after the PAS is with the non PAS being so heavy shes a bit hard to control when the back end comes to play..
ive just ordered a waterpump of ebay for £16 :)
are the gaskets readily available?
Posted: Tue Aug 12, 2008 8:16 pm
by dan_cup
well ive found a complete PAS setup for £75 delivered. seems like a decent price? anyone know if that can be bettered? :wink:
