Got another 1, Fuel gauge issue
Posted: Wed Aug 06, 2008 1:25 pm
by johnny_boymk1
How quick are you lot?
Right i'm just about to attack my dash with a screwdriver to try and get to the back of the fuel needle. Apparently theirs a brass nut behind to tighten up that is usually the prob? the needle twitches about from full to empty then stops on empty. Is this easy can a mechanical retard like me sort it?? cheers
Re: Got another 1, Fuel gauge issue
Posted: Thu Aug 07, 2008 5:27 pm
by Dipesh
my fuel gauge is the same, would be interested on how to fix it!
Posted: Thu Aug 07, 2008 5:38 pm
by march109
You'd have to be a proper retard not to be able to tighten the brass nut, tools required spanner and phillips screwdriver.
Posted: Thu Aug 07, 2008 9:22 pm
by bigredbmw
cool thats another problem i have as well
Posted: Thu Aug 07, 2008 10:24 pm
by Dipesh
Is it just a brass nut then?? I have no idea whats causing it!
Posted: Fri Aug 08, 2008 12:09 am
by Alex
if fuel light works but gauge dont then its will be just the nut on the back
Posted: Fri Aug 08, 2008 4:26 pm
by johnny_boymk1
Hey all. well had the clocks out and it ain't that the brass nut was tight prob a faulty sender unit??
Any one wantin to take the clocks of this guy "320imoredoor" has done a step by step guide and its really good, cheers to all who posted
Posted: Fri Aug 08, 2008 9:30 pm
by johnny_boymk1
