M42 oil leak
Posted: Wed Jul 23, 2008 9:00 pm
by jonboye30
i believe that the oil is coming from the the top of the timing chain cover. how esay is this to replace? i know the timing chain cover is in 2 parts but is the gasket in two parts? i am reasonably competant at working on my car but just wondering if i should tackle it myself or pay someone to do it? any information wouldbe appreciated.Thanks
Re: M42 oil leak
Posted: Wed Jul 23, 2008 11:34 pm
by frogman
I believe the gasket is in two parts, timing case upper and timing case lower.
Re: M42 oil leak
Posted: Thu Jul 24, 2008 2:07 am
by Dave_M3
yep, and there's also a rubber gasket between the upper and lower cover
Best change the gaskets under the rocker cover too when you have it off
Re: M42 oil leak
Posted: Thu Jul 24, 2008 6:32 pm
by jonboye30
Thanks guys, yea i had the rocker cover off to have a look and see where the oil leak was, i originally thot it was the rocker gasket but then realised it was the timing chain cover.
Is it an easy job?
Thanks again for your input.
Re: M42 oil leak
Posted: Thu Jul 24, 2008 6:35 pm
by Sanchez
ive done it.
Gets messy as you can imaging.
try this
http://www.esatclear.ie/~bpurcell/318istimingchain.html
obviously you dont need to do it all but it gets the cover off.
Re: M42 oil leak
Posted: Thu Jul 24, 2008 8:04 pm
by jonboye30
Thanks sanchez, the artical is quite handy. if found that website a while ago but i couldnt remember how i got to it or what it was called so you have done me 2 favours. thanks again every1 for your input.
Re: M42 oil leak
Posted: Wed Oct 15, 2008 6:56 pm
by aj_mckay
jonboye30 - Sorry to dig up an old thread and all that but how did you get on with sorting the leak? I think I have the same thing on mine and am going to have a go at it this weekend. Which gasket did it turn out to be leaking from??
Cheers!
