Rear beams...do they differ?
Posted: Wed Jul 09, 2008 3:43 pm
by bmben
So yeh, are they all the same?or do the diff casings differ?
Ben
Re: Rear beams...do they differ?
Posted: Wed Jul 09, 2008 3:56 pm
by Chris-W
All the same (bar M3 - exhaust hanger difference).
Posted: Wed Jul 09, 2008 4:37 pm
by bmben
hmm...not sure wether this is a good thing or not...my diff just wont line up with it.its on the front 2 mounting and the main chassis one, but the two middle mount are bout 8mm out. any ideas?
Ben
Posted: Wed Jul 09, 2008 4:43 pm
by psychochild187
i would say undo the front ones again not all the way tho . and raise it with a floor jack maybe wiggle it too. it should line up !
Posted: Wed Jul 09, 2008 5:30 pm
by bmben
Thats got it! just me being a spanner instead of using one properly!
Righty, now thats done, i have found another problem. the propshaft doesnt seem quite long enough? the four connecting bolts are just out of reach from the diff pinion flange. the diff's all mounted properly in the four points and the fifth on the chassis.does it retract into the main bearing or flex or sumthin? (first time doin this!!)
Ben
Posted: Wed Jul 09, 2008 5:33 pm
by SPADGE
Loosen the large collar joining the 2 halves of the prop together and lengthen it slightly by sliding the rear end out.
Posted: Wed Jul 09, 2008 5:39 pm
by bmben
awesome, well i shall make meself another cup of tea nd have a go! will keep posted.
Cheers spadge
Ben
Posted: Wed Jul 09, 2008 9:58 pm
by bmben
tis on :D just brakes left to finish off, then i shall hav it back! cant wait :D cheers for all the hints peeps, mucho appreciated. got the new MIM 1900s aswell (could do with a refurb), will put a pic up once its out of garage and clean
Ben
