injector cleaning - opinions
Posted: Mon Jul 07, 2008 10:54 pm
by cro320
What are the known symptoms of clogged fuel injectors?
Is it really necessary to clean them ultrasonic or I just need to put some cleaning fluid in my fuel?
Re: injector cleaning - opinions
Posted: Mon Jul 07, 2008 11:10 pm
by sam325is
Worth the money to have them ultrasonically cleaned. Symptoms are rough idle, loss of responsiveness and if you have leaking injectors your car will be reluctant to start from cold.
Posted: Tue Jul 08, 2008 1:07 am
by psychochild187
where do they leak from ? the spray nozzle or the o-rings
just woundered as my friends car does this
Posted: Tue Jul 08, 2008 8:16 am
by AlpineAde
Dodgy injectors can be noisy too.
They're well worth looking after.
I'm getting mine done when my inlet manifold goes on.
Posted: Tue Jul 08, 2008 3:25 pm
by cro320
well I need to check them first, but to do that I need to take them off
Re:
Posted: Tue Jul 08, 2008 4:45 pm
by rj
You can check the resistance values with them in situ.
Re:
Posted: Tue Jul 08, 2008 6:49 pm
by Martinaston
The only way to check the spray pattern is to remove the whole fuel rail, injectors and regulator and then turn the starter over and have a look at the spray pattern.
The fuel should come out in a cone shape and be a fine mist but what you'll see will look more like a water pistol
If you think there not working correctly then just get them cleaned anyway, it will cut the fuel bill.
Re:
Posted: Tue Jul 08, 2008 8:03 pm
by cro320
rj wrote:You can check the resistance values with them in situ.
how?
Re:
Posted: Tue Jul 08, 2008 10:56 pm
by leeparkes
roughly how much is it to have them cleaned?
Re:
Posted: Tue Jul 08, 2008 11:21 pm
by sam325is
looking at about £100
