Rosejointed Droplinks?
geoffrey
Sat Jun 28, 2008 12:49 am
Has anyone come across a supplier that does rosejointed droplinks specifically for the e30? I've got eibach roll bars and want some decent droplinks.
If no one does them then maybe i will start making some up...
anyway if anyone knows, let me know
cheers
Sat Jun 28, 2008 10:14 am
IIRC, there's a link from a 5(?) series that is the same length as the E30 front ARB link, but has the same joint as the E30 top joint on both ends. Needs a bracket made up for the bottom end to the control arm.
Not a rose joint, but eliminates the rubber.
Sat Jun 28, 2008 10:34 am
Racing dynamics in answer to the original question
monkey
Sat Jun 28, 2008 12:20 pm
i have been thinking about fitting mondeo estate 2000 on rear roll bar links .not rosejointed but with a ball joint on each end with the right size thread . they are cheap and easy to get hold of . have a look here ebay 180156531070 . like i say i havent done this yet but they look and measure up like they will do the job .
DaveD
E30Zone Wiki Specialist
Sat Jun 28, 2008 6:17 pm
you could replace the rubber with a poly bush..
geoffrey
Mon Jun 30, 2008 6:19 pm
Simon13 wrote:Racing dynamics in answer to the original question
Cheers mate.
funky-monkey
Mon Jun 30, 2008 8:19 pm
would the racing dynamics ones fit a standard sport anti-roll bar?.
I ask becouse the car is lowered and there is pre-loading on the anti-roll bar.
Sorry to hijack your post :)
Lacy
Tue Jul 01, 2008 2:18 pm
I may be wrong here but, will it make any difference if the car is lowered?. I thought the ARB acted like a big torsion spring so is only under load when there is a difference in height between the two wheels?
Bob_S
Tue Jul 01, 2008 6:12 pm
you can buy rose joints etc from most good rally supply places PPC mag have plenty of places, it's just a case of make your own.. otherwise you can get them from whiteline @ Demon Tweeks dear but widely avaliable
Bollocks to this 24v scrap!
