Noise from rear?
Posted: Thu Jun 12, 2008 9:55 pm
by jonnie
Guys, i've got a clanging/metallic rattling sound coming from the drivers side rear of my 325 saloon.
I thought it might be the top mounts, but I put new ones on and it hasn't cured it.
Anyone got a ideas/suggestion?
Jonnie
Re: Noise from rear?
Posted: Thu Jun 12, 2008 10:02 pm
by hoshy
When does the noise happen? cruise, turning, accel, decel, over bumps?
If you wanna take a look at the top mounts you can open out the boot lining and bounce the car a bit.
Posted: Thu Jun 12, 2008 10:09 pm
by jonnie
It happens when going over bumps/rutted tarmac.
Its def not the mounts, it has ones on, just fitted.
Posted: Thu Jun 12, 2008 10:32 pm
by stonesie
Has the noise appeared after the new topmounts?
Posted: Thu Jun 12, 2008 11:19 pm
by jonnie
Nope, i was hoping the new mounts would sort it, but hasn't.
Posted: Thu Jun 12, 2008 11:27 pm
by e30topless
usual culprit is the exhaust have you checked the mounts/rubbers ?
Posted: Thu Jun 19, 2008 4:22 pm
by Myke_Gee
I've got a knocking at the rear of my E30 too. Developed about 100 miles after purchase!?!?! Which didn't impress me in the slightest by the way, anyhow, I remember there being a rubber mount attached to the Scorpion system that held a rubber 'block' to space the exhaust away from the rear beam. It now appears to be missing and the gap between the exhaust and the beam has got closer and I presume that this is the cause? Anyone shed some light on it as I can't seem to find a diagram or anything on the net to assist and no one else has any idea at the local garages. Maybe it's an exhaust thing with you too Jonnie.
Posted: Thu Jun 19, 2008 7:43 pm
by Brianmoooore
I wouldn't totaly dismiss the top mounts as being the problem. I've seen several near new ones wrecked by incorrect fitting.
Posted: Fri Jun 20, 2008 11:48 pm
by Myke_Gee
I Placed an excort/orion (as listed at the local HELLfrauds store) exhaust rubber between my stationary rear beam and the top of the exhaust. This cured the 'knocking' I was getting. Now i know it'll burn and eventually wear down, or disappear but it'll do for a trip to Bournemouth and back
Maybe............
