very hard to change gear
snoops
Major Helmet
Sat May 31, 2008 11:08 pm
I have just completed my engine swap to a m20 b20 facelift and it is very very hard to get it into gear
there is a whissing sound when the clutch is engaged and in gear also
any help would be much appreciated
thanks
SPADGE
Sat May 31, 2008 11:50 pm
Snoops
What e30 exactly did you get the flywheel off of?
I'm wondering if it came off an early car like your prop as they may be different and may require a different release bearing!
SPADGE
Sun Jun 01, 2008 12:07 am
One more thing which car did the slave cylinder you are using come off?
It definatly sounds from your description clutch related.
snoops
Major Helmet
Sun Jun 01, 2008 12:37 am
the prop is from an early car and I think the flywheel is too, I will be changing the centre bearing on the prop for a facelift one though
1st second reverse are hard, second is a real pain to get into and third and fourth are just very tight, haven't tried fifth yet
what is the likely cause? release bearing?
re: the slave cylinder, I don't know as I didn't do that part but if there wasn't one included with the bits my dad got off you then I think the original 318i one was used
snoops
Major Helmet
Sun Jun 01, 2008 12:40 am
also with the clutch just a little bit away from the floor when on a normal e30 the clutch is engaged and you are able to change gear, on this I can't change gear, it makes the screeching sound and the clutch has to be right on the floor
suzie650
Sun Jun 01, 2008 2:13 pm
Re-bleeding the clutch might help? The bite point should effectively be higher than that...
snoops
Major Helmet
Sun Jun 01, 2008 5:05 pm
the biting point is much higher where it should be, it's just that the gear doesn't engage properly unless the clutch is full depressed
there is also a tinny metal grinding sound when changing gear
can anyone help
alan325i
Sun Jun 01, 2008 6:39 pm
1st i would replace the slave cylinder with one off a 325i as you said that your gearbox came from a 325i. The one fitted right now is from your 318i then rebleed system.
If that dont work then you have a headache of taking gearbox off and checking the fly wheel is correct.
redchurch
Sun Jun 01, 2008 9:43 pm
I had a similar problem, although not after an engine swap. I changed to slave/master cylinders and that fixed it. Parts are cheap as well.
Ben5732
Mon Jun 02, 2008 4:09 pm
had that problem with mine mate when i first got it turned out i needed a new slave cylinder
