Head gasket
Posted: Mon May 19, 2008 6:24 pm
by teatime39
i have a 1990 320i 6pot and i've been told that the front of the head gasket is leaking , its not mixing but i must say i'm alittle concerned , how much am i looking at to have it done , what are the likely ongoing problems and is there anything i can do
any help would be much appreciated
Re: Head gasket
Posted: Mon May 19, 2008 10:45 pm
by hennabm
If it is from the front OS of the engine then a lot of them do that. Unless very excessive it's nothing to worry about.
Both of mine do it. :roll:
Re: Head gasket
Posted: Mon May 19, 2008 10:54 pm
by teatime39
wicked i think i give it a degrease and jetwash and keep an eye on it see what the score is , still love to know how much replacing it would cost
Re: Head gasket
Posted: Mon May 19, 2008 11:04 pm
by Taylor325i
teatime39 wrote:wicked i think i give it a degrease and jetwash and keep an eye on it see what the score is , still love to know how much replacing it would cost
Depends if your doing it yourself or paying a garage or getting it done by a mate and where the parts are sourced. You can buy a gasket set and new head bolts from GSF for about £50 or buy the parts from BMW for about £150 from memory.
Taylor.
Re: Head gasket
Posted: Tue May 20, 2008 4:07 pm
by teatime39
is there alot of difference in quality , dont think i could do it myself and none of my pals can do it so it would be a garage or someone off the zone
Re: Head gasket
Posted: Tue May 20, 2008 4:10 pm
by JGG1
My brother had the head gasket done on a 320i he had a while ago for £550, no idea if thats the going rate or if he had his pants pulled down though 8O
Re: Head gasket
Posted: Sat May 24, 2008 12:05 am
by dee77nemesis
jay1980 wrote:My brother had the head gasket done on a 320i he had a while ago for £550, no idea if thats the going rate or if he had his
no that price is about right if it was done properly
Posted: Sat May 24, 2008 12:44 am
by mineralblue
On what basis have they told that the head gasket is leaking?
Re:
Posted: Sat May 24, 2008 12:34 pm
by teatime39
i think its seeping oil , also this spring is leaking what is it called and how hard is it to fix is there a gasket in there or something
Re:
Posted: Sat May 24, 2008 2:32 pm
by rj
The spring around the tube is part of the crankcase breather system.
The tube has 2 O rings fitted to the top and bottom.
Re:
Posted: Sat May 24, 2008 6:24 pm
by trigger
quite an easy fix! buy 2 new rubber o rings, push the tube down against the spring tension until you can move the top sideways and draw it away from the underside of the inlet manifold then pull it out and change the o rings, then lube them up with a smear of grease two aid refitting without pinching the new o rings and damaging them then refit in the reverse way of removing it! hey presto job done! although its a bit cramped under there! :D
also are they sure its the head gasket thats leaking and not the rocker cover or the front camshaft oil seal??? :wink:
Re:
Posted: Sun May 25, 2008 1:19 pm
by teatime39
What size are the o rings bro , as for the rocker cover ,i've checked its fine , not sure where the camshaft seal is mate ..
