Brake Master Cylinder help
Posted: Tue May 13, 2008 6:06 pm
Alrite guys,
Need some help with my brake master cylinder, please.
The car is a D-reg 316 (1800cc Carb engine)
I got a replacement brake master cylinder off a zoner a while back, but it was the wrong one. I was wondering if can change the pipe around, and if it will work?
I'll try and show you what i mean
(apologies from the crappy model, only took me two mins and i know its not proportionate lol)
1) Can someone tell me where this pipe goes
2) where 1 comes off on the other brake master cylinder i've got
3) Can some one tell me where this pipe goes
4) Can some one tell me where this pipe goes
5) Resevoir sits on top of here
6) Resevoir sits on top of here
7) connects to brake servo
What i want to know is:
Is it possible to bend the pipe from 1) to 2) and will this work?
ie if the downpipe (1) is for the back brakes then will it work if i connect it to position (2) on the other brake master cylinder ive got?!
Hope this makes sense!
Cheers in advance
Cheers in advance
