Rear droplinks
Posted: Sat Apr 26, 2008 4:48 pm
by Fraz06
Hey guys, Im going to be replacing the rear anti roll bar droplinks shortly and im just looking for some advice, has anyone got any tips on how to manovere the rubber part of the droplink onto the anti roll bar? as it looks like a very tight fit.
Thanks Guys
Fraser
Re: Rear droplinks
Posted: Sat Apr 26, 2008 6:11 pm
by hennabm
I used washing up liquid and brute force to push mine back on.
I used standard links. The old ones came off not too bad but nothing else would let the new ones slip on far enough other than washing up liquid.
ATB doing the job.
Re: Rear droplinks
Posted: Sat Apr 26, 2008 6:15 pm
by old_skool
Just spit on it and give it a good hard push
Re: Rear droplinks
Posted: Sat Apr 26, 2008 7:33 pm
by ian332isport
old_skool wrote:Just spit on it and give it a good hard push
I bet you say that to all the girls
Re: Rear droplinks
Posted: Sat Apr 26, 2008 7:41 pm
by daimlerman
If the ends of the ARB have surface rust,give them a clean up first,it always slides better when it's shiny..as the actress said to the bishop...
Re: Rear droplinks
by austin360
get a tight fitting drill bit and spin it in reverse this will heat the rubber maken it soft iss a bit of copper greese ind it should slip on sounds like a bodge but works
