Page 1 of 2
320i tuning with 325i parts,
Posted: Fri Jun 03, 2005 4:08 pm
by Gunni
Does anybody have any experience with tuning the 2.0 with 325i parts?
the AFM exhaust sides are as big on both,
so in theory a complete 2.5 front install with M30 maf should be possible,
anybody have dyno info on such mods,
I gteched the 2.0 yesterday to reach a average of 9.1 0-60mph( with a 3,25LSD) and 17.2 1/4mile, and assuming 2800lbs 122hp is beeing made, I know it has a substantional vacuum leak, and tomorrow the dyno will tell me the actual horspower.
Again to the question, has anybody modded a 2.0 and what where the gains,
IԚ´m looking for any changes, mileage, 0-60, hp/torque
Posted: Fri Jun 03, 2005 4:09 pm
by Jhonno
3.25LSD? Typo?
Posted: Fri Jun 03, 2005 4:17 pm
by Gunni
Jhonno wrote:3.25LSD? Typo?
nope I used it with my S50B30 motor,
110kmh in second gear,
125kmh@3000rpm in 5th gear
IԚ´m rebuilding the S50 and am going to play with this 2.0 while itԚ´s in there
Posted: Sat Jun 04, 2005 12:13 am
by Brianmoooore
jhonno - the gearbox that comes with an s50/M50 has a 1:1 fifth gear instead of the E30's 1:1 fourth gear, so you need to use a much lower diff ratio. ( I use a 3.19)
Posted: Sat Jun 04, 2005 12:19 am
by Boots_Walker
upgrading to a 325i throttle body has gotten pretty impressive gains for some people
Posted: Sat Jun 04, 2005 1:08 am
by Brianmoooore
Leaving the 325i TB attached to the engine it came from gets better gains.
Posted: Sat Jun 04, 2005 6:25 am
by Boots_Walker
Brianmoooore wrote:Leaving the 325i TB attached to the engine it came from gets better gains.
what are you basing that on? I havent done the swap myself, but others on here have with great results. the 325i unit has roughly 50% more crossectional area...
Posted: Sat Jun 04, 2005 8:23 am
by Jhonno
Boots_Walker wrote:Brianmoooore wrote:Leaving the 325i TB attached to the engine it came from gets better gains.
mate - he's saying leave the tb on the 325i lump n put the whole thing in instead
Posted: Sat Jun 04, 2005 3:37 pm
by 320Touring
jhonno for a 4potter you sure dont give up easily
the 325 tb can be fitted easily enough to the 2.0, as long as the manifold is 'ground' to match
some of us happen to think that the 2.0 is worth the effort
Posted: Sun Jun 05, 2005 1:39 pm
by Gunni
I got this engine for free!!
and I have a complete 325i intake manifold and tb + intake boot, so I was wondering what to expect,
I will inform you ladz on the developments as they evolve
Posted: Sun Jun 05, 2005 5:17 pm
by Gunni
first tuning session
replacing the TB on a Ԛ´89 320i motor with a Ԛ´87 325i TB
320i measured 66mm
325i measured 74mm
AFM ex port is identical in size,
result if true,
better throttle response
before specs by gtech
0-60 : 9,1 best (9,5-9,6 regular)
0-400m : 17,2 best (17,5 regular)
power : 91kw - 123hp
after specs by gtech
0-60 : 8,56 best (9,01 regular)
0-400m : 17,01best (17,2 regular)
power : 93kw - 126hp
dyno measured yesterday
92.6kw
167nm
would like to dyno again but itԚ´s $100 so getch will do.
Overall alot better throttle response,
next IԚ´ll swap the intake manifolds and do more testing.
Posted: Sun Jun 05, 2005 10:37 pm
by Boots_Walker
did you grind out the intake manifold to match the bigger TB or just bolt it straight on?
Posted: Sun Jun 05, 2005 10:48 pm
by Gunni
Boots_Walker wrote:did you grind out the intake manifold to match the bigger TB or just bolt it straight on?
bolted straight on.
I left both gaskets on as the 325i one seemed to be so big that it actually would open a way in from behind th tb on the bottom, i.e the manifold is not big enough to cover the whole hole of the 325i tb,
Posted: Sun Jun 05, 2005 10:58 pm
by Donnie
thanks for this nice thread Gunni, some of us 2.0 boys appreciate it hehehe, I myself am currently in the process of researching on some supercharger setups for the short stroke M20
Posted: Mon Jun 06, 2005 12:35 am
by Gunni
Donnie wrote:thanks for this nice thread Gunni, some of us 2.0 boys appreciate it hehehe, I myself am currently in the process of researching on some supercharger setups for the short stroke M20
it is surtenly short stroke at only 66mm,
at 86mm and 66mm stroke it would have 2300cc exatly
it would be rev happy for sure
When I get the chance to swap to a 2.5 manifold IԚ´ll post the results
Posted: Mon Jun 06, 2005 4:35 am
by Jhonno
worth the effort? kinda like floggin a dead donkey yeah?
Posted: Mon Jun 06, 2005 11:52 am
by elliot
320`s the donkey, 325`s the bucket
Posted: Mon Jun 06, 2005 6:03 pm
by 320Touring
elliot wrote:320`s the donkey, 325`s the bucket
glad to see that someone is willing to put some effort into the 320! i'll follow this thread with interest
Posted: Mon Jun 06, 2005 8:00 pm
by Andyboy1
Brian - to fit a 325i engine into a 320i is a total pain in the arse. It's at least a day of back breaking toil, expense and you'll still have a weedy small casing diff ready to cough.
You'd have to be daft to do it. Just buy a sodding 325i instead.
A throttle body however is a simple and ultra cheap way of making a cheap and cheerful 320i go a lot better. BMW restricted the 2 litre for insurance purposes so all we do is de-restrict them. I ground out the manifold on mine and found that although there isn't enough meat in the bottom of the manifold, it can be radiused off to smooth the air flow.
Throttle body and rubber inlet bellows, Ԛ£10 from a scrapyard. You will need a chip to make it work properly. Mine came from ChippedUk and works a treat. On a 3.64 diff it pulls 60 mph in second gear easily enough. With a 3.91 diff it would probably beat a 318iS and give a 325i a fright.
No, it's not as fast as a good 325i but it's not THAT far behind. 320i's are worth about half the value of a 325i, so it's worth doing.
Posted: Mon Jun 06, 2005 8:28 pm
by Donnie
320touring, I shall be following this thread with the outmost interest aswell
Posted: Tue Jun 07, 2005 9:43 am
by 320Touring
the gains with the 325iTB look good, and will probably be better if the manifold was 'ported' to reduce the step as much as possible
definately makes me more determined to stick with m20b20 'wrongness' and have me a responsive engine thats a bit 'different' from the usual fayre.
I'm not after out and out power, but i want to improve what i consider to be a great engine
Posted: Tue Jun 07, 2005 10:49 am
by Jhonno
Posted: Tue Jun 07, 2005 12:01 pm
by Ade
how different is the opening on the intake manifolds?
Is it impossible to properly match them without resorting to weld?
Posted: Tue Jun 07, 2005 12:35 pm
by 320Touring
Posted: Tue Jun 07, 2005 12:38 pm
by Jhonno
No shame in being inferior then? Fairdo's
Mine is 4 pot wrongness (if it were an m42 or s14 it'd be ok) that kept up with the m20b20 wrongness... plus i wanna go Scooby bashing in my '316i'
Posted: Tue Jun 07, 2005 1:12 pm
by BlackCabrio
AndyBoy 1 wrote:
" ... it's not as fast as a good 325i but it's not THAT far behind. 320i's are worth about half the value of a 325i, so it's worth doing."
The bangs per buck argument is a good one. Plus 320's are more likely to have been gently treated, so the value is enhanced even more.
Andy also said " ... BMW restricted the 2 litre for insurance purposes ..." which makes sense. And presumably the capacity was engineered for certain countries' tax regulations, like Italy I believe.
It really is a nice engine, just needs the airflow. And if you want ultimate power rather than a thoroughly nice car, get a shit hot hatch.
Posted: Tue Jun 07, 2005 1:16 pm
by 320Touring
Jhonno wrote:No shame in being inferior then? Fairdo's
not inferior, just packin a bigger wad
the 316i is a good engine!keep it and mod it
i think too many folk are too interested in followin the heard with the 325i and not putting enough of their own personality into their cars
Posted: Tue Jun 07, 2005 1:18 pm
by Jhonno
hey - i aint going 325i.... try another 0.5 litres n 12 valves
Posted: Tue Jun 07, 2005 1:28 pm
by 320Touring
Posted: Thu Jun 09, 2005 12:09 am
by Gunni
Update
325i manifold installed with stock injectors and fpr.
rought idle,
alot better throttle response and while driving better throttle response.
performance :
0-60 10.3
hp by gtech : 82kw (111hp)
what is blatanly obvious is that itԚ´s running either very rich or very lean,
IԚ´m thinking the later,
IԚ´ll install a 3.0fpr and adjust the afm for idle and part
update later
Posted: Thu Jun 09, 2005 11:38 am
by 320Touring
sounds like quite a drop in performance
but as you say an increase in fuel pressure should help-and increased throttle response is A GOOD THING!
keep up the good work
Posted: Thu Jun 09, 2005 11:45 am
by Gunni
320Touring wrote:sounds like quite a drop in performance
WeԚ´ll see, IԚ´m going to put in a B25 AFM as well today and see what that does, the nafter that IԚ´m putting in a 3bar fpr
I think my air filter is clogged up, on snap throttles the air box sounds to be choking alot.
Posted: Thu Jun 09, 2005 11:51 am
by Donnie
Hey Gunni, again thanks for doing this for the 2.0l boys, get that 3bar FPR on, I am really curious to seeing the results
also put a cone on , just for the tests sake hehe
Posted: Thu Jun 09, 2005 12:37 pm
by Gunni
Donnie wrote:Hey Gunni, again thanks for doing this for the 2.0l boys, get that 3bar FPR on, I am really curious to seeing the results
I donԚ´t think I wanna bother with a cone, as I would have to build a heatshield and such,
but if I donԚ´t have any free time then who knows
Posted: Thu Jun 09, 2005 12:45 pm
by Project_E30
I have fitted a 325 TB onto my 320 inlet manifold. I would like to know whether I should fit the 325 AFM as well or stick with the 320 AFM??
Any advice?
Has anyone done this?
