Royalratch wrote:It's not the advice, just the throw away manner.
We've been discussing different options and actually trying to see if there is a different way for a while. Many have 'suggested' just chucking on all M3 stuff - so thanks for repeating.
I bet you it's cheaper to get hubs machined.
Listen,i work in a machine shop and know that making these would be costly,very costly.
I have researched this imensley and come to the conclusion that the e30 m3 stuff is the easiest way to do this.
Re drilling is out of the question as the hub isnt big enough to support a 120 pcd of holes.It could be re drilled for 5X 100 (audi/vw fitment) but not 5X120.
If you dont want the abs then e36 front struts are cheaper,and with m3 eccentric bushes fitted to the control arms they work.
For the rear,the only thing you need is the 5 stud hub as the trailing arms and bearing are the same on the back,as is the drive shafts.
So there you go,my comment about fitting m3 stuff is VALID !
