Failed MOT on.....Horn and handbrake! (also heater blower)
TheKoose
Tue Sep 18, 2007 4:10 pm
How ironic after doing so much to her in the last 3 weeks to get her ready for her first MOT in a long time, to fail on these.
Any advice on how to sort the horn would help, i seem to remember the heater blower and horn are on the same fused circuit, but i cant bloody find my manual. Any help on which fuse and relay it is?
Many thanks
Mark
Mark
1987 325i Sport (Tech 1)
Rover 220 GTi Turbo (1 of 500)
hongkongfuey
Mad-tango-geezer
Tue Sep 18, 2007 4:48 pm
horn fuse number7 = 15 amp, relay k2
heater blower fuse number 20 = 30amp/relay k7
with cars like mine,
TheKoose
Tue Sep 18, 2007 4:51 pm
Thanks mate :)
Went out to check, the heater blower fuse was broken, replaced it and still nothing. But now when its turned to setting 4 it makes a chunky kindof click after a couple of seconds, its not the relay clicking its something else behind the dash.
As for the horn, very confusing, it works but only if you turn the wheel to the right as you press the horn :?
Mark
hongkongfuey
Mad-tango-geezer
Tue Sep 18, 2007 4:59 pm
what steering wheel you got
TheKoose
Tue Sep 18, 2007 5:34 pm
1987 Tech 1 with tech 1 wheel :)
Mark
hongkongfuey
Mad-tango-geezer
Tue Sep 18, 2007 5:41 pm
i've got a tech 1 wheel, the right horn button does not work, i had a prob with the horn, took wheel off cleaned contact on wheel and car then put on some copper grease on the contacts, some times they get dry .
worked ok accept right button , i've goto sort that when i've got 5 mins
e30-320i
Tue Sep 18, 2007 5:44 pm
It may be the earth on the horn.This is the problem i had see here....
http://www.e30zone.net/modules.php?name ... light=horn
p.s
the temp bodge is still in place and it went through the mot 2 weeks ago :D
89 325i touring
TheKoose
Tue Sep 18, 2007 6:38 pm
Cheers chaps, ideally i dont want to bodge it but if needs must. How do i take the steering wheel off on mine? do i prise out the BM badge?
Any thoughts on the heater blower problem?
Mark
e30-320i
Tue Sep 18, 2007 7:09 pm
yes mate just pop the badge out.
try a search on heater blower there are loads of threads.
89 325i touring
TheKoose
Tue Sep 18, 2007 7:17 pm
Thanks, tried searching but i cant find any threads with the same problem, only ones where the fan only works when switched to setting 4(full) which is a knackered heater blower resistor pack. :(
Mark
