Faulty fuel gauge after m30 swap
Nickk
Sat Sep 08, 2007 12:07 am
Dont know if the fuel gauge worked properly before i did the swap as the car had no engine in it when i got it.
The gauge shows half full but the low fuel light is on.
When i put more fuel in it the gauge goes up and the light goes out and when the level drops to half the light comes back on.I have changed the sender unit but still have the fault/
Any ideas :?
nooster
Mon Sep 10, 2007 5:54 pm
thay is a sender unit on the left and a fuel level indercator on the right under the back seat change the one you havent changed. :mad:
smithy318i
Mon Sep 10, 2007 6:03 pm
sorry to be blunt nooster but thats incorrect.
The problem is with your fuel guage.
There are two different fuel guages (one for single sender tanks and the other for double sender tanks)
swap out the fuel guage with the correct part number and it will read empty when its empty.
Nickk
Sun Sep 16, 2007 9:27 am
HI the gauges in the car are the original ones unless they have been swapped before i got the car.
Sun Sep 16, 2007 9:50 am
First thing to do is look under the round inspection plate under the left side of the rear seat base, to see if there is a level sender there, or you have a tank without it.
Nickk
Sun Sep 23, 2007 8:36 pm
Hi had a look today my car doesn"t have a sender under the left hand inspection plate :?
Sun Sep 23, 2007 8:39 pm
Nickk wrote:Hi had a look today my car doesn"t have a sender under the left hand inspection plate :?
In that case it almost certainly has the wrong gauge fitted.
Nickk
Sun Sep 23, 2007 11:12 pm
Thanks for the info i wiil source another gauge.
smithy318i
Sun Sep 23, 2007 11:17 pm
Part number you require is... 62 13 1 374 825 and i have one for sale if you want to buy it.
Sun Sep 23, 2007 11:36 pm
There are people on here with the opposite problem, who would happily swap with you - if you can find them.
