the pipe which leaves the bottom of the clutch fluid reservoir on my 318is is all rotten ( guessing fluid leak has caused this?) The pipe appears to go into the bulkhead at a totally inaccesible point, just below the battery tray. Has anyone on the zone ever managed to change this ?
Also have a fluid leak from near the gearbox , am i right in assuming that i'l be needing a new slave cylinder as well ?
Paul
