Engines - 318is
amble-gamble
Fri Jun 29, 2007 6:14 am
Right I want to put an (is) engine in an E30 cabby, I just want check if the (is) engine from an E36 is identical to the (is) from an E30.
From what I can find out the manifold was changed and that's it!!!
Please let me know!!!!!!!! :mad:
e30bmlover
Ac Schnitzer prophet
Fri Jun 29, 2007 7:06 am
in a word..... no. two different engines.
tim_s
Fri Jun 29, 2007 7:52 am
e30bmlover wrote:in a word..... no. two different engines.
or in another word, yes, two identical engines! :D
the pre 1993 engines are identical, and the post 93 engines more or less the same. its the bits attached to the engines that are different. the sump, ex/inl manifolds, engine mts and g/b are different. try using the search there's plenty of info on this on here. imo get the latest m42 engine you can, but remember you'll need manifolds, sump etc off the e30.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
E30Mark
Fri Jun 29, 2007 7:53 am
tim_s wrote:but remember you'll need manifolds, sump etc off the e30.
Which I have for sale winkeye
PM for details
Fri Jun 29, 2007 9:36 am
The short answer is that you can easily fit an E36 M42 engine into an E30, as long as you have a scrap E30 M42 engine as well.
amble-gamble
Tue Jul 03, 2007 8:44 am
What about the clutch???????
amble-gamble
Thu Jul 12, 2007 10:56 am
bump
