316i diff change !!??
andrewpany2002
Mon Mar 26, 2007 11:43 pm
hi, my diff has been leaking quite badly recently and i was told that it would be better to change the hole diff insted if replacing the seals which is where it is leaking from, does anybody know if it would be better to use a diff from another car for example an 318i or 320i or somthing insted of an 316i diff ??
thanx
m-dtech
Unapproved Trader caution
Tue Mar 27, 2007 12:00 am
you could use a diff from a 320/325 but check out the ratios first.
316i should have a 4.10 diff, if you go for lower like 3.xx you will loose acceleration but car will sit at lower rpm at speed.
andrewpany2002
Tue Mar 27, 2007 12:11 am
ye i thought so, how about a 318is diff ? do you no the ratio for that ?
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Tue Mar 27, 2007 2:50 pm
iS is 4.10, same as 316i and 318i (except tourings that are 4.27 afaik)
320Touring
Tue Mar 27, 2007 3:13 pm
hoshy wrote:iS is 4.10, same as 316i and 318i (except tourings that are 4.27 afaik)
correct ash!
go to this website and click on the link at the left hand side for e30's
http://www.unixnerd.demon.co.uk/bmw.html
gives engine type, and final diffs found on the car.
also has a gearing calculator so you can play about :cool:
andrewpany2002
Tue Mar 27, 2007 11:03 pm
so if i put a diff from a touring 316i or a 318i ill have betta acceleration ?
