Fitted prop after changing diff to large case, slacked off the bolts that hold the center bearing and the large one so the prop length can change.
When i let it sit natuarally there is no adjustment to push it foward to preload it as it is already at the end of the slider before pushing it foward...
Hope this is clear enough for someone to help me...
so basically its as far foward as it will go before pushing it the 5mm to preload it!!!
